    MSI release?
    J
    I’m looking forward to deploying PowerArchiver 2023 to my users. Can you tell us when the MSI will be available for download and distribution?
    Thanks.
    Security vulnerabilities in 7zip / Update for PowerArchiver and PACL libraries?
    BigMikeB
    Hi there,
    there were some security issues fixed in 7zip:
    https://www.zerodayinitiative.com/advisories/ZDI-23-1165/
    https://www.zerodayinitiative.com/advisories/ZDI-23-1164/
    As it seems, that PowerArchiver and PACL use the 7zip libraries, could you please update them to the latest version?
    Virtual Drive
    E
    From where I get PAVD2023.EXE? PowerArchiver 2023 tries to open it.
    But it seems, it tries to download PAVD2021.EXE.
    Better ZPAQ support
    I noticed that the version of ZPAQ used is older than the latest released 7.15 https://mattmahoney.net/dc/zpaq.html also there seems to be a newer fork that adds several features https://github.com/fcorbelli/zpaqfranz
    It would be useful to implement this latest version (it also maintains the same syntax and behavior as the latest official release if used the -715 flag) and add when opening a zpaq file a choice of the version of the files to show (e.g. as dummy folders represented the various versions present). Since any previous changes are stored with this format, it is possible to extract a snapshot of a certain date/version.
    Bug with "Encrypt Archive" action
    If I open a password-protected zipper file (created with WinRAR but I think that’s irrelevant), open it with PowerArchiver and run “Remove Encryption” on the same file, then reopen it and add a password with “Encrypt Archive,” the resulting archive will be protected with the old ZipCrypto algorithm and not AES as indicated.
    (this can be verified, for example, by trying to open the archive files with Windows Explorer, which does not support the AES algorithm)
    PA 21.00.18 Action / Test behaves oddly for me on .PA files
    PA 21.00.18 running on Windows 7 64 bit.
    I made a big .PA file and thought I’d check it was made correctly with Menu / Actions / Test.
    Discovered:
    a) PA always issues a UAC prompt to do this!
    b) PA always says there are many errors in PA files.
    Solved PowerArchiver resend codes doesn't work
    1507
    • T
      thomas-k
      I’ve logged in to my account and requested my code. But I didn’t got an email.
      Best regards,
      Thomas
        Hi @thomas-k
        please send us an email to support at conexware dot com and we’ll help out.
        Just tested sending codes here, they arrived immediately. It might be the email spam filtering our registration email.
        Send us an email and we can send the registration email and/or send it to you via support.
        • LuxorL
          Luxor Alpha Testers
          I just tried it myself to see if I could confirm.
          It sent mine but it went straight into my spam folder using gmail. Might be worth checking if something similar has happened in your case.
          Windows 10 Home 64-bit
          • T
            thomas-k
            No, I didn’t got an email. My email provider is web.de The spam folder is empty.
            • Brian GregoryB
              Brian Gregory Alpha Testers
              How long did you wait?
              web.de may, like many email providers, make what they think are suspicious emails wait a few hours to see if the sending server retries or not. Most SPAM bots won’t retry.
              • T
                thomas-k @Brian Gregory
                @Brian-Gregory, I wait about 3 days.
                  Hi @thomas-k
