    extracting issue
    7 Posts 2 Posters 3.5k Views 2 Watching
    • MrAngelusM Offline
      MrAngelus
      I recently installed Windows 10 and I needed to install a working sound card driver… but doing the self extracting exe was not working… i needed to extract the files in the self extracting exe so i could follow the instruction for tis old sound driver
      but Powerarchiver wouldn’t extract all the folders in the self extracting exe
      it didn’t error or anything it just didn’t extract everything
      the file is SBA5_PCDRV_L11_3_01_0056B.exe and i got it from creative
      but Winrar had no issue with it
        @MrAngelus said in extracting issue:
        thanks @MrAngelus
        Downloading it and testing it to reproduce and will log in for fixing as necessary
          hi @MrAngelus
          Downloaded the archive and tested it using the latest PowerArchiver 2019. The extracted folders and files seemed to correspond with the files inside the exe archive when opened in PowerArchiver.
          Which folders did you find missing? Please let us know, we’ll take a closer look.
            MrAngelus
            Sorry been busy with Christmas things I did an extract to subfolder with powerarchiver and this is what i get
              MrAngelus
              however I do an extract to sub with winrar and it extracts correctly which you can see here
                MrAngelus
                hope that explains it and this is with version 19.00.59
                  hi @MrAngelus
                  Thanks very much for the update. Was able to reproduce it now and am logging it in for fixing. PowerArchiver indeed does not show the files properly.
                  Thanks again and have a great Christmas!
