    E-Mail problem
    7 Posts 3 Posters 3.7k Views 3 Watching
    • Michael72M Offline
      Michael72
      My OS: Windows XP Home Edition, SP3
      The version number and date of the program: PowerArchiver 2019 Standard 19.00.47 (05/2019)
      How to reproduce the problem
      I have two accounts on my computer. One Michael, and the other Admin.
      I logged in as Michael (normal account with limited rightes).
      Open Microsoft Explorer and select the files I want to compress.
      Click the right mouse button to display the pop-up menu.
      Click on «Compress & E-Mail “olb.zip”».
      I see a dialog box that shows the movement of the zip process. After the zip ends, the mail client window opens, but as soon as it opens it closes immediately.
      See the video clip that demonstrates this.
        Michael72
        This problem, which I experienced, also was in the admin account.
          Hi @Michael72,
          Sorry for the wait, I have finally set up Outlook Express on the XP test machine so that it works and can test this issue.
          After testing, works fine here. After selecting a few files, then choosing Compress & Email, the new email window opened and I was able to send the email with the zip file attached. The email arrived successfully.
          The files that were compressed in your video, are they on a local disk or a network disk?
          I see that they are on disk I: so would like to check if it’s on a local or networked disc as that could be the reason.
            Michael72
            Disk I: is the local disk on which the OS is installed. It happened because I reinstalled the system. The files are in my account. Once again, I checked the problem with the administrator account. The problem is the same. I reset the archiver’s default settings - the problem remains.
              Michael72
              Additional Information:
              To reproduce the problem, load Light Solitude skin by clicking on “View > Skins > Modern Windows 10 > Light Solitude” from the menu.
              If you load Classic Simple skin by clicking on “View > Skins > Classic Toolbar > Classic Simple (fastest)”, it works fine.
                @Mili did you manage to reproduce this one? Thanks.
                Michael72M 1 Reply Last reply Reply Quote 0
                  Michael72 @spwolf
                  @spwolf I am afraid that I will not be able to correctly understand the question, because I speak English badly. I will try to summarize my last post. I switched to using the Classic Simple (fastest) skin and now I do not have such a problem. But if I switch to the Light Solitude skin, then I begin to experience this problem. All of the above is also true for version 19.00.50.
                  P.S. I apologize. After I gave the answer, I realized that the message was not to me. Now I understand everything.
