    Powerarchiver 18.01.04 Problem with scaling.
    3 Posts 2 Posters 1.8k Views 2 Watching
      Daniel.H
      I work with high Resolution Displays, Monitor has 3440 x 1440 100% Scaling. Windows 10 1809.
      Problem is the Main-Windows Text is very small, Menu and Icons have normal size, but the text is very small.
      Is this a setting problem?
      Best regards,
      Daniel
        spwolf conexware @Daniel.H
        @Daniel-H said in Powerarchiver 18.01.04 Problem with scaling.:
        Best regards,
        Daniel
        Hello Daniel,
        Please go to Configuration> View> and in bottom right you will see “Set file listing font” button - change the size to larger one, default should be 9pt… what was it on your end, 6?
          Daniel.H
          Thank you very much. The Setting was 3pt, which is very small. After Setting it to 9pt everything looks fine.
