    Context Menu Icons (right click in File Explorer), general comments
    2 Posts 2 Posters 1.5k Views 2 Watching
    • The_PurSpykT Offline
      The_PurSpyk
      Hi
      I know this was an issue in the beta version of 2018, and it seems to be the same in 2019, the right click menu icons in File Explorer are red, the uninstall icon ion Control Panel is also red?
      When using the new Windows 10 theme, there is a lot of inconsistency between the different modes, in the burners, you have large colourful icons on top of the scree, in ftp mode you have very small icons, seems a bit of a mess at the moment.
      If you select Modern Toolbar, and have the dark theme on in Windows 10, the toolbar has a black background while the rest of the application is white, the 2018 version never had this issue.
        spwolf conexware @The_PurSpyk
        @The_PurSpyk said in Context Menu Icons (right click in File Explorer), general comments:
        Hi
        • red is on purpose for beta versions
        • being improved, but we also did some of it on purpose… in any case, we finished all the changes for next build, it looks tight IMHO.
        • we can implement new windows dark skin for ribbon ui only for the ribbon part, not for the rest of the app as we cant skin only small part of the application while top ribbon is official windows ribbon ui and cant be skinned. You can change this option manually in under Skins> Modern Toolbar> Auto, Dark, Light.
