Tiny UI fonts
I am having an issue where the text in the tree and file list is super tiny and fuzzy. I cannot find where to change this, how can I set it to something I can see? -
@crohan did you check in Configuration> View and see what is the font size there, and then making fonts larger? Let us know what the font size was. Thanks!
- should be 12 or 13
Which version do you have installed? What are the DPI settings of your screen?
If possible, please post a screenshot of how the window looks and we will do our best to assist.Thanks!
I had a similar problem on a Dell Latitude 7212 resolution 1920x1080 scaled at 150% . Goint into Options and Configuration and changing the Skins setting ( switching between Classic Light and Classic Simple) worked for me.
@Mili said in Tiny UI fonts:
@Mili maybe Windows Ribbon interface with large dpi? Check it out.
tried windows ribbon on 150 and 175% and it looked fine
classic and w10 also looked okmaybe try it with the latest update once it comes out @crohan and let us know if it’s still there
were fonts much larger, like in classic view? Since you are testing on regular screen, it would not be tiny like on 4k screen, jusft normal.
Hi, sorry for not replying sooner, I kind of forgot because I was expecting e-mail notifications (I am watching the issue). But I digress.
My OS is Windows 10 1809, although 1803 had the same behaviour. DPI is set to 100%, and I only have FHD monitors (1920x1080).
@Johnny Thanks, I tried this but it did not solve my problem :(
we will optimize this better in next build of 2019… default values when editing fonts were tiny, so if by accident you checked fonts and clicked ok without changing default value, it would save as 6pt or 8pt… so now we will make sure proper default values are used.
Thanks @spwolf , that was indeed the problem! Nothing was selected under “Font size” so I guess it just used 6 by default. Anyway, set to the desired size and all is good again!
