    Power Archiver 20018 and Outlook 2016
    22 Posts 3 Posters 12.9k Views 3 Watching
      MDuss
      Hi Spywolf.
      When you are in the add-ins menu from the option and you want to open the configuration from an other addin like for example “Microsoft-Exchange-Add-In” do you get then the windows which tells you that this add-in have no configuration settings or do you get the window from powerarchiver although you have selected for example the “Microsoft-Exchange-Add-In” Add-in?
      MfG
      MDuss
        spwolf conexware @MDuss
        @MDuss said in Power Archiver 20018 and Outlook 2016:
        Hi Spywolf.
        MfG
        MDuss
        In the future update, we will remove separate add-in menu in options, so you will be able to configure it via toolbar only, as Microsoft wants. That way there is no confusion.
        Let us know if you notice anything else, thank you!
