    Fast Ring: PowerArchiver 2018 18.01.04
    7 Posts 3 Posters 5.4k Views 3 Watching
      New version: PowerArchiver 2018 18.01.04
      Download Windows Installer: https://powerarchiver.cachefly.net/2018/powarc180104.exe
      Download Portable Installer: https://powerarchiver.cachefly.net/2018/powarcportable180104.exe
      Release Notes - PowerArchiver - Version 18.01.04
      ** Story
      • [PA-1856] - UAC elevation for rar, 7z, pa formats
      ** Improvement
      * [PA-1856] - auto open first level in folder treeview when archive is opened
      * [PA-1880] - Save last used encryption settings for 7z
      * [PA-1886] - Ability to move Compress w Options to shell submenu
      * [PA-1892] - Buttons not aligned in nag screen
      * [PA-1906] - modern: preview toolbar missing
      * [PA-1908] - powerarc -archive test.zip should open archive in archive mode
      ** Task
      * [PA-1871] - update Korean translation
      * [PA-1903] - Make my documents default folder for Browse button in Office/PDF encrypt(decrypt) tools
      ** Bug
      * [PA-1876] - Backup: Update New Backup script save dialog
      * [PA-1881] - 7z does not encrypt filenames in encrypt tool
      * [PA-1882] - Encrypt Tool does not ask to save password after archive creation as in main PA/shell
      * [PA-1889] - remove zip archives from treeview in advanced add window
      * [PA-1891] - better support for encrypted zipx (jpeg codec)
      * [PA-1911] - Compression options show when right clicking .nco file
      Whats New
      • Major news is that we have re-worked support for UAC elevation when user tries to compress or extract to any folder that required administrative rights. Now this will work with any file format inside PowerArchiver, including PA, zip, 7zip, rar, cab, iso, etc.
      • Improved support for winzip jpeg when aes encrypted.
      • Various different improvements and fixes.
      Thanks for the reports @Alpha-Testers. It is November, and we know what starts in November, right @Alpha-Testers ?
      • Brian GregoryB Offline
        Brian Gregory Alpha Testers
        Patchbeam update fails updating from 18.00.58 on Windows 7 64 bit.
        Link to portable version doesn’t work, just delivers a web page.
          spwolf conexware @Brian Gregory
          @Brian-Gregory said in Fast Ring: PowerArchiver 2018 18.01.03:
          should be fixed either now or in next 5m… thanks for the heads up. Version is actually 18.01.04!
          drteethD 1 Reply Last reply Reply Quote 1
          • drteethD Offline
            drteeth @spwolf
            @spwolf
            I am getting the same issue in getting a web page (https://www.powerarchiver.com/download-powerarchiver/) and not patchbeam. It does not seem to be fixed yet.
            Cheers
            DrT
            • drteethD Offline
              drteeth @drteeth
              @drteeth said in Fast Ring: PowerArchiver 2018 18.01.04:
              @spwolf
              Cheers
              DrT
              It seems to have been fixed as patchbeam is working as expected when PA is upgraded to the version at the top of this page.
              Cheers
              DrT
                spwolf conexware @drteeth
                @spwolf
                Cheers
                DrT
                Cheers
                DrT
                so where did it not work? From previous .58? Thanks!
                • drteethD Offline
                  drteeth @spwolf
                  @spwolf
                  That is right. The issue was with .58 and with the latest version, no problems.
                  Cheers
                  DrT
