    No Move with Compress with Options
    5 Posts 2 Posters 4.6k Views 1 Watching
    • B Offline
      bigdog
      I found an odd bug today. I selected 4 or 5 JPGs from the desktop and then right clicked and hit Compress To with Options selected 7z as the format and then wanted to change Add to Move. The problem is that it only allows Add not Moving files into this archive.
        spwolf conexware @bigdog
        @bigdog said in No Move with Compress with Options:
        That option is not available with 7z format now… In general, we don’t like deleting files as there are many things that can go wrong.
        • B Offline
          bigdog
          Just curious why disabled with 7z format but not others? Basically the process is the same no matter the format. Copy files into the new archive, verify validity, and then delete (wipe) the original files.
            we have better access with other engines than with 7z/pa…
            • B Offline
              bigdog @spwolf
              @spwolf said in No Move with Compress with Options:
              Interesting… well hopefully that can be resolved at some point.
