    Fast Ring: PowerArchiver 2018 18.00.58
    6 Posts 3 Posters 22.2k Views 3 Watching
      New version: PowerArchiver 2018 18.00.58
      Download Windows Installer: https://powerarchiver.cachefly.net/2018/powarc180058.exe
      Download Portable Installer: https://powerarchiver.cachefly.net/2018/powarcportable180058.exe
      Release Notes - PowerArchiver - Version 18.00.58
      ** Improvement
      * [PA-1854] - Add/improve keyboard functions for file/tab handling inside PA
      ** Task
      * [PA-1837] - update hebrew translation sent 6/20
      * [PA-1839] - publish cmd switches for PA startup in different modes (archive, explorer, etc)
      * [PA-1842] - update dutch translation sent 6/25
      ** Bug
      * [PA-1835] - HLKM information stays after uninstall
      * [PA-1843] - Backup: Create Solid Archive checkmark text does not show completely
      * [PA-1844] - Backup: 7Z and PA formats do not work - compresses into 0kb files
      * [PA-1852] - Mousewheel up over tab in PA creates a new tab
      * [PA-1855] - Backup: align file size text to the right
      * [PA-1857] - Backup: checking “Save relative folder info” creates corrupt archive due to incorrect paths
      * [PA-1858] - PA format throws nag screen in Toolbox
      * [PA-1859] - Deflate64 checkbox unchecked when restarting Config
      * [PA-1860] - Deflate64 checkbox does not appear in Add window properly when it is to appear by MRU
      * [PA-1862] - Portable: AES encrypted files not extracting properly
      * [PA-1865] - tar.gz file asks for UAC even when not needed
      * [PA-1868] - Join Tool creates 0kb archives for Zip format
      Whats New:
      • Fixes and small Improvements
      • Keyboard shortcuts for handling tabs:
      Ctrl+w-> Close tab
      Ctrl+t-> Create tab,
      Ctrl+Tab-> Focus on forward tab
      Ctrl+Shift+Tab-> Focus on previous tab,
      Ctrl+1-> Focus on 1st tab, Ctrl+9-> Focus on last tab, Ctrl+2~8-> Focus on 2~8th tab
      Thanks to our Korean translator for sending these suggestions in!
      This update is first published only on the forums. Then on 7/27 it will go onto the patchbeam — fast ring. Thank you for testing @Alpha-Testers !
      1 Reply Last reply Reply Quote 3
        @Alpha-Testers added it to the fast ring yesterday… should go live Monday. Thanks!
        • drteethD Offline
          drteeth
          Is the use of mouse buttons for going forwards and backwards in a folder structure, like in Windows Explorer, being considered. I made the suggestion some time agao and STILL try to use my mouse buttons before realising that they do not work in PA.
          Cheers
          DrT
          Brian GregoryB spwolfS 2 Replies Last reply Reply Quote 0
          • Brian GregoryB Offline
            Brian Gregory Alpha Testers @drteeth
            @drteeth It’s many years since I even saw one of those multi button mice in a shop let alone owned one. I think if they do this it’ll be just for you.
              spwolf conexware @drteeth
              @drteeth said in Fast Ring: PowerArchiver 2018 18.00.58:
              Cheers
              DrT
              as brian pointed out, I dont have this on any of our mices… so we have to wait a bit for vacation times to be over, so I can get one with this to ivan :)
              • drteethD Offline
                drteeth @Brian Gregory
                @brian-gregory
                Brian,
                “In a shop”? How quaint :slightly_smiling_face: .
                It is difficult to buy a regular-sized mouse without them these days. Just look on Amazon.
                It also irks me when there is a functionality in windows that I use, that many programs implement and a few do not :frowning_face: .
                IMHO, not an unreasonable request.
