    Solved Burner / Virtual drive : empty selection screen (2018v37)
    • pirrbeP
      pirrbe Alpha Testers
      In Burner / Virtual Drive / Add Virtual Drive : here you must have the fields to select your ISO to mount = just an empty screen. ??
      • pirrbeP
        pirrbe Alpha Testers @spwolf
        @spwolf Indeed, deleting the pavd and forcing back the dl/install of pavd driver solved the problem !! I noted dawn the solution for next time :-). Thx for quick help.
          spwolf conexware @pirrbe
          @pirrbe Virtual Drive did not change… maybe update to Windows means drivers have to be reinstalled? Delete pavd*.exe and make it redownload again. Thanks!
          pirrbeP 1 Reply Last reply Reply Quote 0
          • pirrbeP
              @pirrbe good to know! It is good to have the solution here for people who search for it in the future. With Windows 10 being updated so much, i guess it will happen occasionally.
