    Solved PowerArchiver 2018 Archive Rename and Reload
    • C
      ckit Alpha Testers
      PowerArchiver 2018 needs to be able to re-open\reload an archive after the archive has been renamed via File Menu or shortcut key
      In the screenshot below, I downloaded “SysinternalsSuite 2018-02-10.zip” but got the date wrong in the filename. When I corrected it in PA…
      spwolfS 2 Replies Last reply Reply Quote 1
        spwolf conexware @ckit
        @ckit Please check it out in latest internal release:
        http://dl.powerarchiver.com/2018/powarc180034.exe
        Should be fixed now. Thanks!
          @ckit thank you!
            • C
              ckit Alpha Testers
              Confirmed!
              Huge TY
