    Offline code does not work
    5 Posts 2 Posters 3.5k Views 1 Watching
      davidsplash
      seems a problem with the latest version of powerarchiver that offline registration code does not work however the online code does why is this.
        spwolf conexware @davidsplash
        @davidsplash said in Offline code does not work:
        as usual, offline codes are based on specific version while online ones work with any version.
        So I assume you are trying PA 2017 offline codes with PA 2018 and it wont work while online codes will.
        If you need offline codes for PA 2018, email support and we will send them over (in case you plan to use it on computer thats offline).
          davidsplash
          Thanks though i was using a 2018 code with a 2018 powerarchiver managed to register via online way but not the offline way.
          oh well at least im registered now anyway. just thought you guys should know
            are you sure it does not say 2017 specifically? Unless we sent them manually, there is no way to get PA 2018 offline codes now.
              davidsplash
              i bought the 2018 version with lifetime licence and it came with online and offline registration.
