    Archive Test Results Box
    6 Posts 4 Posters 2.6k Views 2 Watching
    • B Offline
      bigdog
      I know this issues has been in PA for quite awhile now and seems to remain in PA 2017. When testing an archive the results box “disappears” behind the main window forcing you to have to look for it. It should remain on top of the main window until you close it.
      spwolfS 1 Reply Last reply Reply Quote 2
        spwolf conexware @bigdog
        @bigdog where are you starting test from and what OS? If we knew about it and reproduced it, we would have fixed it before. Thanks a lot!
        • C Offline
          ckit Alpha Testers
          Do you have “Always on Top” enabled on the Options menu?
          I can reproduce with “Always on Top” enabled, however I can’t access PowerArchiver at all afterwards!!! Using Alt-Tab I can see the Test results window but not open the window and same for PA!
          Had to right click on Taskbar app, Close and de-activate Always on Top
          Windows 10 Pro x64 1704 with MBAM Premium protecting “powerarc.exe”
            yes, occurs when Always on Top is selected.
            we have logged it in, many thanks for the tips!
              looks fixed in .83, thanks for the help friends!
              • C Offline
                ckit Alpha Testers
                Confirmed
