    Issues with translations
    5 Posts 2 Posters 2.7k Views 1 Watching
    • N Offline
      nikkho Alpha Testers
      I am running PA 17.00.69 in spanish, and have detected some issues with the translations.
      In some cases, strings are larger than the available space in the control (TCheckbox, TLabel, …). In other cases, the controls are not long enough to fit the complete text, even if there is available space.
      Find attached some screenshots of the forms I have detected:
      Compress
      Compress-Options-Advanced
      Options-Misc
      Options-View
        spwolf conexware @nikkho
        @nikkho do you have time for 10-20 new strings each year? Editing translation files is very easy through editor and current translator is not a PA user. Thanks!
        • N Offline
          Sure. I can contribute in the translations, if the volume is only 10-20 per year.
            @nikkho usually yes, since there is massive amount of already translated strings. But since you use PA, you can see things that our regular translator wont spot. I will send you files later. Thanks!
            • N Offline
              @spwolf looking forward for the files. Also please, take a look at TLabels that even if enough available space on screen, are not wide enought. Maybe you can use Delphi Autosize or something in that cases.
