    Fast Ring: PowerArchiver 2017 17.00.64/65/66
    3 Posts 2 Posters 4.3k Views 1 Watching
      Release Notes - PowerArchiver - Version 17.00.64/65
      ** Improvement
      * [PA-32] - Save setup choices in registry (checkboxes)
      * [PA-532] - PAOP Update
      * [PA-813] - add RWZ to the compressed extensions in strong/fast modes
      * [PA-824] - change reflate/hif codec switches
      * [PA-830] - speed up .pa file list loading
      * [PA-834] - add .md to the auto preview text list
      * [PA-835] - update zstd2 to zstd3
      ** Task
      * [PA-837] - update patchbeam web page link
      ** Bug
      * [PA-19] - PA associates with archives during installation
      * [PA-189] - Cannot cancel RAR extraction
      * [PA-407] - associate asks to associate again after installation
      * [PA-481] - 125 DPI in inno installer
      * [PA-804] - ratio % off if block size is over 4GB
      * [PA-814] - W7 installation freezes at “Registering files”
      * [PA-818] - Finnish installer shows incorrect language text
      * [PA-819] - Installation always in English
      * [PA-823] - Progress window title bar shows wrong filename when extracting via extract button
      * [PA-829] - Cannot cancel PA extraction from main PA extract button
      Release Notes - PowerArchiver - Version 17.00.65
      ** Improvement
      * [PA-839] - make secure aes default aes implementation in .pa format
      ** Bug
      * [PA-681] - backup - issue with using pa and winaes
      * [PA-746] - Filename encryption not working when SECURE AES selected for PA format
      * [PA-776] - Filename encryption in PAES does not work (fast aes)
      * [PA-798] - extract archive to… menu does not appear in shell
      * [PA-817] - Deleting archives on Windows 7 (files in use)
      * [PA-849] - Update translations for PowerArchiver and Setup
      PA 2017 17.00.66 download:
      http://dl.powerarchiver.com/2017/powarc170066.exe
      PA 2017 17.00.66 Portable download:
      http://dl.powerarchiver.com/2017/powarcportable170066.exe
      Whats New
      Fixes for reported issues from Beta 1. Major change is that we have updated our Zstandard implementation to ZSTD3 with updated mt wrapper module. We have also made “secure aes” default encryption codec. As a reminder, secure aes uses BWTS codec to scramble data before aes encryption that is done by validated (fips 140-2) modules from Windows. It speed peaks at around 50MBs but is overall more secure than just standard aes implementation. We have also enabled header encryption for secure aes as well.
      So please test AES encryption and lets make sure everything works properly before it gets released to the wild next week.
      Thanks everyone and have a nice weekend!
      PA Team
      1 Reply Last reply Reply Quote 3
      • guidoG Offline
        guido
        why isn’t available via patchbeam?
        Windows 11 Pro ENU x64
        Intel Core I7
        32 GB RAM
          spwolf conexware @guido
          @guido said in Fast Ring: PowerArchiver 2017 17.00.64:
          it is more like an alpha… few more fixes left plus need to check this one too.
