    VirusScan Problem
    3 Posts 2 Posters 7.5k Views
      Serhiy
      Hi!
      PA VirusScan feature requires full path to the virus scanner EXE file
      I use Norton AntiVirus 2005.
      So I chosen “NAVW32.EXE” in Configuration>Program Locations…
      But it doesn’t work. PA still show “You must configure virus scanner before using this feature…” message.
      Then I provided full path to NAVW32.EXE:
      “С:\Program Files\Norton Internet Security\Norton AntiVirus\NAVW32.EXE
      And it works fine…
      So this is a bug:
      WinZIP works fine with “NAVW32.EXE” (only exe file name)
      Regards,
      • A Offline
        ACTANO GmbH
        Just use a really right AV-Scanner like McAfee ;).
        This will be work. :D
        Henry
          Serhiy @ACTANO GmbH
          But I like Norton AntiVirus :-)
          • “The world’s most trusted antivirus solution”
