Fast ring: PA 2016 16.10.19/20
Version:
PA 2016 16.10.19/.20/.21Download:
http://dl.powerarchiver.com/2016/powarc161021.exeWhats new:
.19
- Small improvements for progress bar
- Fixed issue with >4 GB files that have 0 byte files at the end.
- Changed trial options, expiration, reset trial counter.
- Improved behaviour when network folder is set as default folder.
- Added “efolder” option for setting default Extract folder location (Enterprise users).
.20
- Patchbeam installer fix
- Small changes for registration window.
.21
- Fixed crc error in specific ZIP archive.
Thank you!
No patchbeam included in this build?
@Brian:
how do you mean brian? It is on fast ring?
Version 16.10.19 doesn’t seem able to check for further updates, it just directs me to the website.
@Brian:
can you please check location of patchbeam.exe, is it in root or in Patchbeam\ folder?
@Brian:
we figured out that it happens when you upgrade, but not when you do fresh install. We will investigate, thank you!
return of the patchbeam:
http://dl.powerarchiver.com/2016/powarc161020.exe -
Latest:
http://dl.powerarchiver.com/2016/powarc161021.exe- fixed an issue with CRC error in specific ZIP archive.
The choose a file location page of the installer has a minimize and restore button. the other pages don’t
see image
hmmm. I cant seem to add a image
