    Fast ring: PA 2016 16.10.13
    8 Posts 5 Posters 5.4k Views
      Version:
      PA 2016 16.10.13
      http://dl.powerarchiver.com/2016/powarc161013.exe
      Whats new:
      • Progress bar fix
      • moles42M Offline
        moles42 Alpha Testers
        it’s showing as 16.00.13
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
        A Brian GregoryB 2 Replies Last reply Reply Quote 0
        • A Offline
          ACE135 @moles42
          I can’t open RAR archives with this version.
          • Brian GregoryB Offline
            Brian Gregory Alpha Testers @moles42
            @moles42:
            Same here. But the about box correctly shows 16.10.13.
              Brian Gregory Alpha Testers @ACE135
              @ACE135:
              Same here.
              Then clicking OK on the error message results in “POWERARC.EXE has stopped working”.
              I’m running it under 64 bit Windows 7 Ultimate.
                thanks everyone! logging it in
                  thanks guys, we tested few things for next major release so now we have to make sure that everything works fine in upcoming minor update.
                    Version:
                    PA 2016 16.10.14
                    http://dl.powerarchiver.com/2016/powarc161014.exe
                    Whats new:
                    • Small fixes and improvements
