    Some problems with the extracting window
    5 Posts 3 Posters 3.8k Views
    • A Offline
      ACE135
      There seem to be some problems with the extracting window of PA version 16.10.12.
      The displayed elapsed time isn’t displayed correctly. It is displayed in the format 00:00:00. The first 60 seconds it is displayed correctly. The most right 2 digits show the seconds. After 1 minute only the middle 2 digits count up from 1 to 59 and the right ones stay at 0. After minute 2 the left digits show the minutes and the middle ones show the seconds and the right ones stay at 0.
      When extracting via shell the file name of the first file that is extracted isn’t displayed. When extracting via main window then it is displayed.
      When extracting via main window then for the elapsed time is displayed a “?” for about 5 seconds. When extracting via shell then the elapsed time is instantly displayed.
      I just tested this with some multi-volume rar archives.
        Thanks for letting us know. Pretty weird timer behavior we will check it out right away.
        • A Offline
          ACE135
          Thanks for the fast response.
            great find, thanks very much!
            • A Offline
              ACE135
              There are still some problems with version 16.10.14.
              When I extract an archive (RAR) via shell then the first extracting file still isn’t displayed.
              Next thing is that, when extracting via main window, the extraction can’t be canceled. When I click on the cancel button and then on “no” PA keeps extracting. After that the cancel button doesn’t work anymore. And if I click on the cancel button while the extraction is paused then the extraction will be continued.
