    Fast Ring: PA 2016 16.02.04
    7 Posts 2 Posters 4.6k Views
      Fast Ring release: PowerArchiver 2016 16.02.04
      Whats New:
      • Improved default RAR settings
      • Compress to .rar now uses settings set in Config
      • FTP log now shows latest line first.
      • Small dpi fixes in Config window
      http://dl.powerarchiver.com/2016/powarc160204.exe
      Thank you for your support!
      • skypxS Offline
        skypx
        Norton Security is up to shenanigans again! Got this after installing the latest beta.
        ASUS Crosshair VII Hero
        AMD Ryzen 9 5700X
        T-Force DDR4 3600 32GB
        Samsung 970 EVO 2TB
        GTX 3080ti
        Win10 x64
          spwolf conexware @skypx
          @skypx:
          i think i even said last time that I thought that they did not fix the problem with their detection engine but rather simply whitelisted the crc… I will have to report it again.
            @skypx:
            can you update it and try again? They told us it was fixed last night… not sure if that update reached users yet. thanks!
            • skypxS Offline
              skypx @spwolf
              Good news, Norton Security got a ~10MB update yesterday and after a reinstalling of 16.02.04 it did not intervene. So the issue may have been fixed, or the file in question was white listed after the installation yesterday.
              AMD Ryzen 9 5700X
              Samsung 970 EVO 2TB
              GTX 3080ti
              Win10 x64
                @skypx:
                thanks, let me know if it happens again and we will be checking it out as well. They told us that file was whitelisted via signature.
                  new fast ring release:
                  http://www.powerarchiver.com/forums/showthread.php?p=34929#post34929
