    Fast Ring: PA 2016 16.02.02
    10 Posts 5 Posters 5.4k Views
      Fast Ring release: PowerArchiver 2016 16.02.02
      Whats New:
      • Major improvement and rework of FTP functionality.
      • Fix for pae2 format support.
      • New settings for 7z compression at Ultra
      • Added icons preview and separators to Classic toolbar customization window.
      • Minor changes on how compression profiles in shell are shown.
      • Various small icon changes.
      • Fix for RAR w/ encrypted filenames support in shell.
      • Fix for 7zip compression in shell when same filename exists.
      • Other smaller changes.
      http://dl.powerarchiver.com/2016/powarc160202.exe
      Or via Patchbeam of course. Thanks everyone for sending their requests in!
      • guidoG Offline
        guido
        the text in the frame is the wrong font.
        See image
        Windows 11 Pro ENU x64
        Intel Core I7
        32 GB RAM
          spwolf conexware @guido
          @guido:
          See image
          it is HTML page… what font should it be? :)
          • guidoG Offline
            guido @spwolf
            same as the one above.
            Intel Core I7
            32 GB RAM
            • moles42M Offline
              moles42 Alpha Testers
              current build fails to recognize a psd in the viewer and
              reports it as an (unknown picture file extension).
              Windows 10 Pro x64
              Intel Core i5 3470 @ 3.20GHz
              8.00GB Dual-Channel DDR3
              • Brian GregoryB Offline
                Brian Gregory Alpha Testers @guido
                @guido:
                Why?
                  Mili conexware @moles42
                  @moles42:
                  was it recognized and shown in preview prior to this last release?
                    spwolf conexware @Mili
                    @Mili:
                    i think it was always showing up… maybe we should disable it? It is possible that it supports some older version of PSD, but it is annoying to get error message.
                    • moles42M Offline
                      yes the problem has been with us for a couple of the latest releases…
                      I’d hoped it was just a hiccup that had surfaced with all the current updates that were happening.
                      Windows 10 Pro x64
                        new release:
                        http://www.powerarchiver.com/forums/showthread.php?p=34864#post34864
