    Using zips on unfished cd's causes problems
    4 Posts 3 Posters 6.6k Views
      davidsplash
      i use directcd from adptec and sometimes pa archive has problems wirth them. Winzip on the other hand does not (used to test if archive is ok )
        deipotent
        This might be related to the problem I reported with PA crashing when trying to test several ZIP’s on an un-finalized CD-RW.
          spwolf conexware @deipotent
          What exactly is the problem david? Writing, reading, testing?
          Please, step by step process so we can understand.
            davidsplash @spwolf
            sorry about the delay computer was being mended. the problem is that sometomes powerarchiver stops responding for a while while working writing or opening/ extracting to cds and zip drives.
