    Encrypting using PA and .pae2.
    6 Posts 2 Posters 4.3k Views
      mkelfer
      Using PA 16.00.67 and am trying to make the simplest encrypted .pae2 file. I started PA, selected the Encrypt Files icon. In the subsequent Encrypt Files window, the destination format is pae2. I add the two files using Add Files, leave encryption options (aes-256) and compression options alone. Group to a single file (use the default name). Press encrypt. Put the password in. Goes to the Encryption Files progress page and just hangs indefinitely.
      Any ideas?
        how large are the files?
          mkelfer @spwolf
          3MB total. I cannot get it to work at all.
          M spwolfS 2 Replies Last reply Reply Quote 0
            mkelfer @mkelfer
            a little add’l info…win 10 pro x64 1511.104
              spwolf conexware @mkelfer
              @mkelfer:
              thanks, we will check it out in the morning……
                fixed:
                http://www.powerarchiver.com/forums/showthread.php?t=6534
