    ZIPX-Jpeg-decompression does not work
    4 Posts 3 Posters 2.8k Views
    • J Offline
      jmattner
      Hi there,
      Jpeg files compressed with Winzip using jpeg compression
      cannot be extracted with PA 2016. PA 2015 worked well.
      Is the zipx-Jpeg-compression no longer supported?
      I had to revert to PA 2015.
        Please check with this latest release:
        http://dl.powerarchiver.com/2016/powarc160064.exe
        It should work fine… our zipx/jpeg engine was omitted by mistake in previous release. Thanks!
          SMH17 @spwolf
          Now zipx seems working in 16.00.64 but other problems that I have reported (eg on 7-ZIP and ZPAQ) are still here in this version
            spwolf conexware @SMH17
            @SMH17:
            we will update those other threads when we have solutions for those other problems of course.
