    [BUG] ZPAQ Compression doesn't work correctly
    3 Posts 3 Posters 2.9k Views
      SMH17
      When I try to compress a folder with ZPAQ, the compression stuck before completion at 55% or 99% then stops
      If I try to compress few jpg images works but when I try compress more complex folders that contains mixed file types (program binaries, images, sounds and txt files) always same issue.
      Note:
      If I check Power Archiver process during ZPAQ compression the CPU and RAM usage is pretty low during the operation compared to other formats.
      My PC: i7 Ivy Bridge 16 GB RAM Windows 10 x64 all update installed
      Power Archiver Version: 16.00.61
        @SMH17:
        Note:
        thanks for letting us know, we will check it out tomorrow.
          thanks for letting us know, we have logged this in
