    16.00.56 RC3 not showing translations in shell x86
    9 Posts 2 Posters 4.8k Views
    • A Offline
      Alan Cuteri
      Was PowerArchiver 2016 Professional v16.00.46 RC2, after updating to version v16.00.56 RC3, in kontektstnom menu of Right mouse button-> menu was in English, “Извлечь в” become “Extract to”, the settings set Russian language.
        @Alan:
        thank you, can you add a screenshot here? I wrote this in after I saw your comment, I just want to make sure I have seen it properly (and written it in).
        thank you!
        • A Offline
          Alan Cuteri @spwolf
          thank you!
          • A Offline
            Alan Cuteri @Alan Cuteri
            Error in version 16.0.9.1 PASHLEXT.DLL, replacing a version 16.0.6.1.
              Alan,
              can you please go to PowerArchiver Options> Set language and manually once again change it to Russian, does that fix anything? Thanks!
              • A Offline
                Alan Cuteri @spwolf
                It does not help. I wrote above that I have the default options set in the Russian language.
                  spwolf conexware @Alan Cuteri
                  @Alan:
                  thanks, we are looking into it… will update you as soon as we figure it out.
                    thank you for your report.
                    We have fixed this issue and improved translation module across the application. Now everything should be translated, everywhere.
                    Here it is:
                    http://dl.powerarchiver.com/2016/powarc160058.exe
                    thank you!
                    • A Offline
                      Alan Cuteri @spwolf
                      Here it is:
                      thank you!
                      Thank you. Now everything works well. :)
