    PowerArchiver Toolbox 2016 [16.00.46] => right-click crashes of Explorer.exe etc.
    9 Posts 3 Posters 5.7k Views
    • T Offline
      TONSCHUH
      I bought the PowerArchiver Toolbox 2016 [16.00.46] via here: Click
      When I right-click a file / folder / shortcut etc.pp. via Desktop, File-Explorer, Total Commander Ultima Prime etc.pp., then I get pretty much every 2nd time a “blabla had to be closed” - Error and the Explorer.exe restarts itself or closes the File-Explorer / Total Commander Ultima Prime if I’m lucky or completely takes off me the ability to right-click.
      Faulting application name: explorer.exe, version: 10.0.11099.1000, time stamp: 0x56918bfb
      Faulting module name: PASHLEXT64.DLL, version: 16.0.6.1, time stamp: 0x567a6bc2
      Exception code: 0xc0000005
      Fault offset: 0x00000000000306f1
      Faulting process ID: 0x4ea4
      Faulting application start time: 0x01d1526a75a9c9d4
      Faulting application path: C:\WINDOWS\explorer.exe
      Faulting module path: C:\Program Files (x86)\PowerArchiver\PASHLEXT64.DLL
      Report ID: b1dfdd24-4949-4562-ac65-29f83f5b9cec
      Faulting package full name:
      Faulting package-relative application ID:
      • System
      • Provider
      [ Name] Application Error
      • EventID 1000
      [ Qualifiers] 0
      Level 2
      Task 100
      Keywords 0x80000000000000
      • TimeCreated
      [ SystemTime] 2016-01-19T03:55:54.964936700Z
      EventRecordID 2671
      Channel Application
      Computer MOTHER-PC
      Security
      • EventData
      explorer.exe
      10.0.11099.1000
      56918bfb
      PASHLEXT64.DLL
      16.0.6.1
      567a6bc2
      c0000005
      00000000000306f1
      4ea4
      01d1526a75a9c9d4
      DXDIAG: Click
      I have no issues with other stuff.
      :confused:
      • C Offline
        ckit Alpha Testers
        Please try build 53 - http://www.powerarchiver.com/forums/showpost.php?p=34606&postcount=62
        • T Offline
          TONSCHUH @ckit
          @ckit:
          Thanks for your help, but it didn’t solve the issue unfortunately.
          Here are the errors for the different tries:
          Total Commander v8.52a / Total Commander Ultima Prime v7.0:
          Faulting application name: TOTALCMD64.EXE, version: 8.5.2.1, time stamp: 0x00000000
          Faulting module name: PASHLEXT64.DLL, version: 16.0.8.1, time stamp: 0x568fd3b0
          Faulting process ID: 0x2be0
          Faulting application start time: 0x01d152af85c0558f
          Faulting application path: C:\Program Files (x86)\TC UP\TOTALCMD64.EXE
          Report ID: 227c0e69-6aca-483a-9f5e-2ec2a3574484
          • System
          • Provider
          • EventID 1000
          [ Qualifiers] 0
          Level 2
          Task 100
          • TimeCreated
          [ SystemTime] 2016-01-19T12:39:27.093038300Z
          EventRecordID 3024
          Channel Application
          Computer MOTHER-PC
          Security
          • EventData
          TOTALCMD64.EXE
          8.5.2.1
          00000000
          PASHLEXT64.DLL
          16.0.8.1
          568fd3b0
          c0000005
          00000000000306f1
          2be0
          01d152af85c0558f
          File Explorer:
          Faulting application name: Explorer.EXE, version: 10.0.11099.1000, time stamp: 0x56918bfb
          Faulting process ID: 0x249c
          Faulting application start time: 0x01d152af7632a073
          Faulting application path: C:\WINDOWS\Explorer.EXE
          Report ID: 0c4ecb2e-7165-4091-85c1-e5c0c29a2e42
          • System
          • Provider
          • EventID 1000
          [ Qualifiers] 0
          Level 2
          Task 100
          • TimeCreated
          [ SystemTime] 2016-01-19T12:40:38.221749200Z
          EventRecordID 3026
          Channel Application
          Computer MOTHER-PC
          Security
          • EventData
          Explorer.EXE
          10.0.11099.1000
          56918bfb
          PASHLEXT64.DLL
          16.0.8.1
          568fd3b0
          c0000005
          00000000000306f1
          249c
          01d152af7632a073
          Desktop Shortcut:
          Faulting application name: SystemSettingsBroker.exe, version: 10.0.11099.1000, time stamp: 0x56918de6
          Faulting module name: SettingsHandlers_Notifications.dll, version: 10.0.11099.1000, time stamp: 0x56918ea0
          Fault offset: 0x000000000002a551
          Faulting process ID: 0x2598
          Faulting application start time: 0x01d152b3a5fc09b6
          Faulting application path: C:\Windows\System32\SystemSettingsBroker.exe
          Faulting module path: C:\Windows\System32\SettingsHandlers_Notifications.dll
          Report ID: c4cdc306-4e6a-4608-9ae2-4efb595df3bf
          • System
          • Provider
          • EventID 1000
          [ Qualifiers] 0
          Level 2
          Task 100
          • TimeCreated
          [ SystemTime] 2016-01-19T12:40:55.901450000Z
          EventRecordID 3029
          Channel Application
          Computer MOTHER-PC
          Security
          • EventData
          10.0.11099.1000
          56918de6
          10.0.11099.1000
          56918ea0
          c0000005
          000000000002a551
          2598
          01d152b3a5fc09b6
          Faulting process ID: 0x3714
          Faulting application start time: 0x01d152b6a3945c51
          Report ID: f2390bbd-b321-4e12-9997-355db62ff9c6
          • System
          • Provider
          • EventID 1000
          [ Qualifiers] 0
          Level 2
          Task 100
          • TimeCreated
          [ SystemTime] 2016-01-19T12:43:07.898766600Z
          EventRecordID 3032
          Channel Application
          Computer MOTHER-PC
          Security
          • EventData
          explorer.exe
          10.0.11099.1000
          56918bfb
          PASHLEXT64.DLL
          16.0.8.1
          568fd3b0
          c0000005
          00000000000306f1
          3714
          01d152b6a3945c51
          All apps / tools are bought. No cracks etc.pp.
          :confused:
            Can you try uninstalling PA 2016, rebooting and then installing it again please?
            Thank you!
              As a fast workaround, can you please set language manually to English or other language you might be using. This is in Options> Language.
              After that check it out, it should be working.
                Please check this release:
                http://dl.powerarchiver.com/2016/powarc160055.exe
                And let us know how it goes… should be fixed. Thank you.
                • T Offline
                  TONSCHUH @spwolf
                  Thanks a lot for your help !
                  v16.00.55 doesn’t have the right-click issues anymore.
                    spwolf conexware @TONSCHUH
                    @TONSCHUH:
                    thanks, this was due to automatic language selection and we fixed it in one of the internal releases but it came back… since we already knew what it was and we noticed it day before, we were able to quickly fix.
                    • T Offline
                      TONSCHUH @spwolf
                      Awesome work !
