    PA 16.00.46 Virtual Drive
    7 Posts 3 Posters 4.8k Views
    • drteethD Offline
      drteeth
      I am using the Virtual Drive on my Win 10 x64 partition. I know I can do this but I have forgotten, how do I set up a ‘right-click > mount’ and ‘right-click > unmount’ for drive images?
      There should be an option in the shell extension config tab, but I cannot find it.
      Mni tnx,
      DrT
      • moles42M Offline
        moles42 Alpha Testers
        I must assume you have installed the ‘virtual drive’ drivers because
        without them as I recall the options for the shell extension don’t appear.
        this was the case on my Windows 10 x64 set-up.
        actually you’re right…I’m not seeing them in my shell configuration either…
        I’ve just checked.
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          i wrote this in and also few other things for VD that will make things easier in the future. Thanks!
            PA 2016 .50:
            http://dl.powerarchiver.com/2016/powarc160050.exe
            PAVD .08:
            http://dl.powerarchiver.com/2016/pavd21008.exe
            Should now detect PAVD installation and auto add VD extensions.
            Question - should they be in root or submenu by default?
            • moles42M Offline
              I generally add them to sub-menu.
              I use all PA options in sub-menu’s.
              I’m still not seeing the VDrive options in shell. (Windows 10 Pro x64)
              Windows 10 Pro x64
              • moles42M Offline
                Update !
                I had to remove latest drive emulator and use windows 10 default options to mount ISO…
                I then reinstalled Virtual Drivers and the option returned to shell menu but it doesn’t
                actually show the option in the shell configurations menu…did you decide to remove it perhaps ?
                After I closed PA the ‘mount / unmount’ options have once again disappeared from the shell menu.
                Windows 10 Pro x64
                  spwolf conexware @moles42
                  @moles42:
                  Update !
                  PA is overwriting settings that VD is setting. So install VD and then run PA.
                  We will get them back to config.
