    Problem with FTP connection
    25 Posts 4 Posters 12.1k Views
    • P Offline
      phil
      no better, sorry…
      hope this reg didn’t change too much my registry, huh ?? ;-)
        not much :))
        (just edited the kaspersky ft[ server address)
        been testing, but always connects properly.
        Basically, you just start PA, go to FTP tab, select server and click Connect?
        Just want to make sure we are going about it the same way.
        • P Offline
          phil
          yes yes, as you say !
          just to remind you, i already made it work !
          • P Offline
            phil
            Hi again,
            just an idea, could you check these CCleaner REGS please, some PA components are inside (attachment) : something bad ??
            i won’t be able to talk here until tomorrow night, so back in 24 hrs !
            attachment_p_34212_0_pa-ccleaner.cab
              maybe some PA setting for FTP changes, did you send Mili via email your settings? That way he can check with your updated setting to see if it works on his computer… i assume he is testing with ones that work for you :-)
