    Problem with FTP connection
    25 Posts 4 Posters 12.2k Views
    • P Offline
      phil
      Hi all,
      W10 with latest updates…
      I’m just realizing I can get no more FTP connection with 15.04.03, with none of the servers I’m usually connecting with.
      It used to be OK with older versions.
      What happens please ? :eek:
      Phil
      French translator
      • P Offline
        phil
        Me again, sorry.
        I made a new fresh install with “repair” option, and it seems to be OK now.
        I think updating with patchbeam went kind of wrong !
        Good day all. ;)
          Thanks for letting us know phil! Glad it worked out :)
          • P Offline
            phil
            hi,
            i think there’s a real problem with ftp connections !
            doesn’t work again… but works very fine with Filezilla or synchback pro
            thank you
            phil
            french translator
              spwolf conexware @phil
              @phil:
              hi,
              thank you
              phil
              french translator
              what seems to be the problem, cant connect or?
              • P Offline
                phil
                hi,
                yes, can’t connect at all, says user and password are bad, but they are OK with other software
                i did a clean install a few days ago, just after that it did work, but after a restart, problem appears again…
                  It connects fine for me here whenever I try to log in.
                  does not work for you on some servers and works fine on others for example?
                  • P Offline
                    phil
                    hi,
                    all of them…
                    • RJWaringR Offline
                      RJWaring
                      Hi Phil,
                      Before going further just check or confirm that you have tried your FTP Connections via Passive Mode ‘Disabled’ or ‘Enabled’. If that doesn’t work and as time consuming this may be please try the following;
                      1. uninstall Powerarchiver and all it’s other drivers and software ie Virtual Driver & Patchbeam then delete it’s location within your Program Files.
                      (Its worth if not already , downloading CCleaner for free and using their disc cleaner and registry repair a few times after you have removed powerarchiver and rebooted)
                      2. Make sure Windows is up to date with the latest updates.
                      3. Download the Powerarchiver and run a clean install.
                      4. Configure PowerArchiver from scratch not importing any backups or cloud imports.
                      Try the FTP Feature then and let us know if you get anywhere with it?
                      If your still unable to get through to your FTP Service after all of the above let us know.
                      • P Offline
                        phil
                        good day sir richard, and all of you
                        I did what you suggested, deinstall, ccleaner, restart and reinstall PA
                        ftp connections are OK again !
                        i think the problem occured with the latest update via patchbeam, but as I said before, i did make a reparation install a few days ago, that made ftp work for only one day ! it was broken again after the first morning restart ! very stange to me !
                        hope tomorrow will be ok !
                        thanks again to you !
                        • RJWaringR Offline
                          RJWaring @phil
                          Your more than welcome Phil I myself have suffered the odd ftp issue it’s a mixture of patch beam and certain files or registry items not registering correctly. I really can’t be too sure as it’s not something that happens too often.
                          But my advice would be give it a few days testing and if you suffer no more issues make a backup of your settings to cloud or file with the version and date in the file name ie pa_160018_121015. That way if issues occur you can run a clean up then restore to a known working config relevant to the version you installed. .
                          If you have problems or questions we are always here to help.
                          • P Offline
                            phil @RJWaring
                            thank you !
                            • P Offline
                              phil
                              hi,
                              after a few days, the problem is back again…
                              FTP connections are down with PA… but still works with other software… something I don’t understand.
                              bye.
                                can you provide a sample FTP account that you cannot log into and that we can try here?
                                You can email the info to support at conexware dot com
                                we’ll take a look
                                  Also, please export your settings and please .cab them and send them over as well. thanks
                                  • P Offline
                                    phil
                                    hi,
                                    please try this one, anonymous, working with Filezilla but not with PA
                                    attachment_p_34204_0_pa-mallet-ftp-problem.cab
                                      Mili conexware @phil
                                      @phil:
                                      hi,
                                      got it, reproduced, many thanks!
                                        the FTP address in the PA FTP profile end in extension .pdf
                                        I notice that FileZille removes the extension when logging in and logs into the ftp (.com) properly.
                                        If you use ftp2.kasperskyftp.com only, as the ftp address, it will work in PA as well
                                        • P Offline
                                          phil
                                          no, it won’t
                                          i did try this before ;)
                                          just to check again, i just tried 30 seconds from now, doesn’t work… (ftp2.kasperskyftp.com)
                                            can you try with this .reg please
                                            attachment_p_34208_0_pa-mallet-ftp-problem.cab
