    OP: Help
    4 Posts 3 Posters 6.7k Views
    • guidoG Offline
      guido
      The help button doesn’t work
      Guido
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
        If you are referring to the HELP button in OutLook Plugin Beta 1, then I confirm. :D
        With MS Outlook 2003.
          ivan conexware @TBGBe
          The issue will be fixed in next release!
          • guidoG Offline
            guido @ivan
            Fixed in .06
            Guido
            Intel Core I7
            32 GB RAM
