    [Solved]Archive with subfolders - problem with extraction
    5 Posts 2 Posters 3.6k Views
    • N Offline
      Nizaury
      I have the archive with this structure:
      SysTracerPro.zip ->
      ––>SysTracerPro (with 2 subfolders)
      ------------>SysTracer_32-bit (with files)
      ------------------->data (empty folder)
      ------------>SysTracer_64-bit (with files)
      Link: http://www.mirrorcreator.com/files/1DVP9WSW/
      And I have the problem with extraction data from this archive.
      The Windows Explorer and 7-Zip open/extract all data from archive with “data” subfolders, but PowerArchiver 14.06.02 open/extract all data from this archive without “data” subfolders.
      • N Offline
        Nizaury
        The PowerArchiver v14.06.03 was released.
        The “data” folders from that zip-file still not visible in PowerArchiver, but are visible with Windows Explorer and with 7-Zip.
          this has been reported into our bug tracker… expect resolution in next beta, not these minor updates… should be soon (same for new 7z engine)
          • N Offline
            Nizaury
            The problem solved in PowerArchiver v14.06.04.
            Thank you.
              Nizaury - thanks … since you report so many usefull things, you have earned free license for PA Toolbox with lifetime updates… email to support at conexware.com with your info so we can send you the code… thank you!
