    Help
    2 Posts 2 Posters 2.1k Views
    • T Offline
      Testereees
      Здравствуйте! скажите как поставить пароль на новый создаваемый архив? найти не могу. Спасибо
      Hello! tell me how to put a password on a new The clone archive? I can not find. thank yo
        hello,
        simply click the “Encryption” dropdown menu when creating an archive and select the encryption you would like, then proceed to complete creating the archive and it will be encrypted/password protected.
        if you have an archive that is not encrypted/password protected, you can open it in Po werarchiver and click the Encrypt button in toolbar and you will be able to encrypt the file then.
        Hope that helps, let us know if we can help further.
        Thanks,
