    PA 2013 Toolbox Drag and Drop Crash
    5 Posts 2 Posters 6.1k Views
    • C Offline
      ckit Alpha Testers
      PA 2013 Toolbox was open, I manually selected all files (there is no easy way to do this with the checkbox method, fuming…) dragged them onto the Explorer window with the Target folder already opened and BANG!
      I’ve attached NirSoft’s AppCrashView log
      attachment_t_6129_0_appcrashview-log-for-pa2013.txt
        tried this and could not reproduce.
        opened archive with folder inside, navigated to the folder and D&D a few files insde. Worked fine.
        Anyone else?
        Also, you can try zipping your settings and sending them over to support at conexware dot com and we can try that reproducing it way as well.
        to save your settings, please click the dropdown arrow below the configuration button.
        • C Offline
          ckit Alpha Testers @Mili
          Ok, here’s my config.
          I get the sinking feeling this has something to do with “Kaspersky Internet Security 2014 (patch E)” I’m going through it’s settings setting up exclusions for PA 2013 and see how that goes.
          attachment_p_32005_0_ckit-s-pa2013-1402.7z
            it’s possible……just for testing purposes, try killing the Kaspersky process completely in Task manager. You’ll only then be sure that kaspersky isn’t getting in the way.
            Let us know how it goes and I’ll give a try here using your reg settings.
              Tested here w your reg settings, worked just fine.
              Let us know how it went with the Kaspersky test.
