    Problem opening
    11 Posts 2 Posters 5.3k Views
      Socrates Banned
      Unfortunately, I cannot give you much information here. But the last 3-4 days I have suddenly had trouble opening a number of different archives.
      I do not know if the archives are corrupted or if PA has a glitch. But this has happened a number of times now, and it is very disconcerting. I am losing data right and left.
        can you send us one of these files as a sample?
          this has been fixed in 14.01.06 - issue with dropbox files where first file in a archive was /.
            Socrates Banned
            The upgrade has not fixed the problem with reading zIps created via Dropbox.
            Still sits there churning saying “Reading folder.”
              Socrates Banned @spwolf
              Unfortunately not. Just posted.
                hm, i tested against file you sent us over - chapters.zip, all works fine?
                  Apologies.
                  I thought I had updated. It was a bit slow, so I must have hit the cancel button.
                  Stupid me.
                    most important part - it works?
                      Socrates Banned
                      Yes.
                      Question. Is AC down?
                      I did have trouble a few days ago; then it worked fine.
                      Now I am wondering if, when down, I screwed up my PW.
                      Or if it is down again?
                      BTW, it is only AC; I can connect to dropbox and google drive without a hitch.
                        try it now, should work….
                          THAT did it.
                          Moreover, thanks for adding the ability to delete files from the AC.
