    Problems handling jpeg-compression of .zipx-archives
    5 Posts 2 Posters 4.8k Views
    • J Offline
      jmattner
      The latest PA 2013 RC2 has an annoying bug:
      when trying to extract a Winzip .zipx-file using jpeg-compression PA2013RC2 only displays an error message and doesn’t extract files correctly if at all.
      PA2012 extracts .zipx-jpegs without any problems.
      Has the feature to handle (extract, test) .zipx-jpeg-files been removed or is it a bug?
        hm, it shouldnt be a problem… let us test.
          thank you for bringing us this to attention… it will be fixed in the next release and we will let you know.
            hello, please test with this release, it should be fixed:
            http://dl.powerarchiver.com/2013/powarc140031int.exe
            thank you,
            • J Offline
              jmattner @spwolf
              seems to work now. Thanks.
              Jens
