Navigation
    • PA 2.00.01 macOS extract popup not showing buttons
      F
      From within PA on the extract popup, buttons are hidden, I must resize the window to get access to the OK/Cancel buttons. Tried on the default notebook screen (Macbook M1 Max 14") as well as on my external monitor (4k).Screenshot_2022-05-12_10-02-10.jpg
    • PA 2.00.01 macOS directory separator inside RAR
      F
      Just uncompressed a RAR file that has a folder within, PA created the folder but the files inside are not being saved into folder because directory separator is a BACKSLASH (Windows style) instead of SLASH (macOS).Screenshot_2022-05-12_09-59-08.jpg
    • Conexware update
      OS: W10 21H2 19044.1645
      Best regards
      Wilfrid
      PS: Keep building such good software
    • PDF Encrypt and Sign Section Missing
      Ho già contattato il supporto con il modulo presente qui https://www.powerarchiver.com/it/contact/ da settimane ma non ho ricevuto riscontro e ora che ho aggiornato alla versione 21.00.15 ho notato che il problema persiste.
      Quando clicco PDF Encrypt & Sign nel tab Crittografia appare la schemata riportata sotto come se mancassero le funzionalità.
      I’ve already contacted support with the form here https://www.powerarchiver.com/it/contact/ weeks ago but I haven’t received any feedback and now that I’ve updated to version 21.00.15 I’ve noticed that the problem persists.
      When I click on PDF Encrypt & Sign in the Encryption tab the schematic below appears as if the functionality is missing.
    • PowerArchiver 2022 Final does not find external DVD-Burner
      U
      I have tried to burn a DVD with PowerArchiver 2022 Final, but it didn’t work because PA didn’t found the external DVD-Burner.
      I have tried several burners from Sony, LG, Dell.
      I have connected the burners with several USB-Ports but unfortunately without any success.
      With other burning software, e. g. Nero, all burner worked perfect on each USB-Port.
      The same problem occured with PA2018 and it was solved with an update, but I don’t remember the detailed software version.
      Could you check the possibility of an bug, please?
      Thank you for your support in advance!
    • PowerArchivier don't save Created and Accessed timestamp
      Quando creo un archivio zip con un altro programma ad esempio Winrar se apro il file con Winrar vi sono visualizzati anche le date originali di Accesso e Creazione.
      Se ottimizzo quel file zip con la funzione Ottimizza archivio di PowerArchivier (o creo un nuovo archivio) il file risultate non ha più le date originali di Accesso e Creazione.
      C’è una opzione per preservare questi dati? (Non l’ho trovata nelle impostazioni del programma e ho già abilitato le opzioni “salva info complete cartella” presente in “Profili di compressione”)
      When I create a ZIP archive with another program such as Winrar, if I open the file with Winrar, the original Access and Creation dates are also displayed.
      If I optimize that zipper file with the Optimize Archive function of PowerArchivier (or create a new archive) the resulting file no longer has the original Access and Creation dates.
      Is there an option to preserve this data? (I haven’t found it in the program settings and I have already enabled the “save complete folder info” options in “Compression Profiles”)
    • Unlisted pbs files
      pirrbe
      Upgraded from 2021 to 2022. Selecting ‘backup’ no scripts are showed. Only after editing and saving an existing script (explorer) it shows up in the PA backup folder.
      So is the ‘backup’ icon to open the Backup screen only for creating ‘new’ ones. This means that you have to open ALL your old pbs files and to save them again… not user friendly.
      No way to improve this ? Thank you.
    • Fast/Slow Ring: PowerArchiver 2022 Final - 21.00.15
      M
      PowerArchiver 2022 - Final Version - 21.00.15
      https://powerarchiverdl.cachefly.net/2022/powarc210015.exe
      Information about PowerArchiver 2022 - 21.00.15:
      https://www.powerarchiver.com/2022/04/05/welcome-to-owerarchiver-2022/
    • Access violation with scaling > 100%
      K
      I have a 31" 4K screen with 3840x2160 pixel, which PA is able to handle - except of a scaling other than 100%.
      When changing scaling for this screen to 125%, starting PA brings the following exception:
      Access violation at address 0000000..DF47A4 in module 'powerarc.exe'. Schreiben of address 0000...00330.
      After closing this message, PA seems to work fine.
      PA version 21.00.15 (03/2022) 64bit (tested with Win 10 and after upgrade Win 11)
      Is there any chance to avoid this access violation or this message?
      Thanks and regards,
      Karsten
    • PA 21.00.13 *.tar.xz open okay but *.txz doesn't
      Brian Gregory
      Example file: http://www.kk5jy.net/smalldv-v1/Software/smalldv-1.0-beta-20180619a.txz
      PA 21.00.13 doesn’t seem to see the contents unless I change the extension to .tar.xz
    • configure clouds hangs up system
      pirrbe
      This are the steps :
      in Options, select ‘configure clouds’ try now to quit this option…
      No way, everything is locked up, the only way is using the task manager to quit PA.
      (version 2021-20.10.02)
    • 2022 RC 2: Adding file to existing archive breadcrumb nav does not work
      MarcFou
      When adding a file into an existing archive, in the add file window, if you click in the breadcrumb bar to navigate to a parent directory, the file list does not change. The directory Up button works.
      Running x64 on Win 11
    • About box slightly messy on PA 21.00.13
      Brian Gregory
      blue text over graphic: (graphic too low?)
      (Running on 64 bit Windows 7)
    • Windows 11 context menu "Open with PowerArchiver" doesn't work
      BigMike
      In PA 21.0.13, when I try to open an archive with the new Windows 11 context menu item “Open with PowerArchiver”, a PowerArchive instance is opened, but the archive is not loaded.
    • PA 2022 Windows 11 context menu not translated
      BigMike
      the new Windows 11 context menu is not localized in PA 21.00.13.
      While the classic context menu is localized, when it’s opened on a file on my desktop, it’s English, when it’s opened from a file on my C drive.
      @Mili Are there updated localization files available?
    • Problems with registry restrictions on PA 2021 and sending reg codes
      BigMike
      I thought, I’ll give it a try and upgrade my PA 2018 Toolbox on my production machine to PA 2021 (20.10.03)
      Sending registration codes in your order recovery doesn’t seem to work at the moment (I also checked my junk folder), online activation works Using registry to disable modules (for example HKLM\SOFTWARE\PowerArchiverInt\General\DisableBurning) doesn’t work as expected with modern ui. The module is visible, but I’ll get the trial nag, if I try to open it. It’s almost fine in classic and ribbon mode.
      “DisableClouds” and “DisableExplorer” seem not to be respected at all, while the classic UI seems to respect the setting to disable any other unused module:
      In settings I won’t be able to access the SmartAI settings and the settings for the internal editor if the FTP module is disabled
    • Is PA 2022 clear with old bugs?
      G
      PA Queue does not compress file optimally with same parameters if used in Queue mode.
      Being able to save advanced option, and set a default profile and archive type for compression so I can save clicks.
      The above two are majorly affecting my efficiency with archiving stuff with PA 20.10.03.
      Can someone confirm if they are resolved with the 2022 RC1?
    • PA Starter - CPU Overhead
      PA_Fan
      I’m running W10 Pro on an HP i-7 machine with now 32gb of RAM. The system drive is an SSD.
      In the course of sorting out some inconsistencies in a couple of my .pbs jobs, I’ve been paying close attention to the system CPU resource and power consumption of PA Starter, as shown by the various resource management tools. I’ve also been trying to identify why my system seems rather sluggish despite some extensive tuning for speed etc.
      When I have enabled Starter as a start-up programme, to use the PA Queue facility, I see that Starter consistently uses between 10-13% of CPU, with High Power consumption indicated. It runs, consuming this resource, irrespective of what may be happening with PA and any pbs script jobs.
      I can understand a need to use a good chunk of CPU when Starter is actually handling PA jobs, but it shouldn’t sit and consume this amount when it really isn’t doing anything but wait for a job to start and for which it is needed.
      Perhaps I’ve missed a way of lessening Starter’s impact, but in the meantime I’ve adjusted my set-up to running PA without it.
      Suggestions, please.
    PowerArchiver Encryption Suite
    • drteeth
      drteeth last edited by
      This is stated to be a separate application in the beta 1 email I got.
      I am very interested in this. Is more info available? Like release date and pricing ;) ?
      Also, I just cannot see any advantage to the select plan in spite of reading the page http://www.powerarchiver.com/powerarchiver-select-premium-support-maintainance/.
      PA updates just fine now, so what advantage does this ‘new’ method give?
      DrT
      • spwolf
        @drteeth:
        DrT
        When PA 2014 rolls out with new keys, you will not have to do anything but click on update, it will automatically update the keys… plus better support, etc. It is really meant for business users, which always had something similar but not clearly defined - we are only company that provides phone support in this space for instance, so now we can tell them - look, competitor provides only upgrade assurance, and here you get much more.
        As for personal users, it makes life little bit easier, plus it also gives you means to support PA development. Both development and support are on-going, not one time costs of course :-). We also plan to give home users a chance to get free Select by posting on forums as well.
        As to Encryption Suite… we will define it a little bit better once we are done with PA 2013. It needs more features then right now, we will see.
        • drteeth
          I have d/l the beta and will install it once my current backup run has finished. The reason why I asked about the Encryption Suite is that the paragraph describing it does not make it clear whether it is a separate app or included in PA - it can read both ways. I have been looking for a good PGP alternative for AGES and am looking forward to this development.
          I assume that it is okay to install over the top of PA 2012?
          DrT
          • spwolf
            spwolf conexware @drteeth last edited by
            @drteeth:
            DrT
            it is included in PA, so nothing extra to install.
            It is an separate application but it works fluidly within PowerArchiver.
            keep in mind we just started with PGP :-). Any suggestions would be awesome.
            • drteeth
              I installed over the top and the install program deletes the older version.
              Still having problems with the driver letter being assigned to a virtual drive when an image is mounted. It looks like the driver for virtual drive fails. Please see screenshots. The installing driver window was present for well over a minute.
              I manually installed the Starport drivers and updated them to the latest version. They appear to be installed okay but there is no virtual DVD-ROM showing as a result (further screenshot added).
              I can work around this issue (I have Virtual CloneDrive installed and working) but do not like to let computers win ;).
              Regards
              DrT
