Its a long time since people reported bugs like converter bug still no fix yet
Configuration:
Powerarchiver 2021 20.00.73
Windows 10 Education 10.0.19042 Build 19042When extracting gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar.xz , Powerarchiver wrongly thinks some .exe files have a length of zero:
Once extracted:
D:\Temp\Powerarchiver\gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf\bin>dir *.exe Volume in drive D is DATA Volume Serial Number is 0E12-BCA2 Directory of D:\Temp\Powerarchiver\gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf\bin 2020-11-20 07:10 PM 1,391,599 arm-none-linux-gnueabihf-addr2line.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-ar.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-as.exe 2020-11-20 07:41 PM 3,030,119 arm-none-linux-gnueabihf-c++.exe 2020-11-20 07:10 PM 1,389,293 arm-none-linux-gnueabihf-c++filt.exe 2020-11-20 07:41 PM 3,027,513 arm-none-linux-gnueabihf-cpp.exe 2020-11-20 07:10 PM 4,040,503 arm-none-linux-gnueabihf-dwp.exe 2020-11-20 07:10 PM 391,769 arm-none-linux-gnueabihf-elfedit.exe 2020-11-20 07:41 PM 0 arm-none-linux-gnueabihf-g++.exe 2020-11-20 07:41 PM 3,026,926 arm-none-linux-gnueabihf-gcc-10.2.1.exe 2020-11-20 07:41 PM 609,607 arm-none-linux-gnueabihf-gcc-ar.exe 2020-11-20 07:41 PM 609,607 arm-none-linux-gnueabihf-gcc-nm.exe 2020-11-20 07:41 PM 609,607 arm-none-linux-gnueabihf-gcc-ranlib.exe 2020-11-20 07:41 PM 0 arm-none-linux-gnueabihf-gcc.exe 2020-11-20 07:41 PM 2,165,533 arm-none-linux-gnueabihf-gcov-dump.exe 2020-11-20 07:41 PM 2,343,605 arm-none-linux-gnueabihf-gcov-tool.exe 2020-11-20 07:41 PM 2,450,233 arm-none-linux-gnueabihf-gcov.exe 2020-11-20 07:54 PM 9,605,899 arm-none-linux-gnueabihf-gdb.exe 2020-11-20 07:41 PM 3,028,997 arm-none-linux-gnueabihf-gfortran.exe 2020-11-20 07:10 PM 1,412,943 arm-none-linux-gnueabihf-gprof.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-ld.bfd.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-ld.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-ld.gold.exe 2020-11-20 07:41 PM 25,546,567 arm-none-linux-gnueabihf-lto-dump.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-nm.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-objcopy.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-objdump.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-ranlib.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-readelf.exe 2020-11-20 07:10 PM 1,393,083 arm-none-linux-gnueabihf-size.exe 2020-11-20 07:10 PM 1,392,464 arm-none-linux-gnueabihf-strings.exe 2020-11-20 07:10 PM 0 arm-none-linux-gnueabihf-strip.exe 32 File(s) 67,465,867 bytes 0 Dir(s) 1,002,422,431,744 bytes freeWhen the same archive is being extracted from a git bash session (after having installed git 2.30.1 for Windows 64 bit version from git-scm.com), the .exe files are extracted as expected:
xz -k -d gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar.xz tar xf gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar cd gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf/bin ll *.exe -rwxr-xr-x 1 User 197121 1391599 Nov 20 19:10 arm-none-linux-gnueabihf-addr2line.exe* -rwxr-xr-x 2 User 197121 1421598 Nov 20 19:10 arm-none-linux-gnueabihf-ar.exe* -rwxr-xr-x 2 User 197121 2028927 Nov 20 19:10 arm-none-linux-gnueabihf-as.exe* -rwxr-xr-x 2 User 197121 3030119 Nov 20 19:41 arm-none-linux-gnueabihf-c++.exe* -rwxr-xr-x 1 User 197121 1389293 Nov 20 19:10 arm-none-linux-gnueabihf-c++filt.exe* -rwxr-xr-x 1 User 197121 3027513 Nov 20 19:41 arm-none-linux-gnueabihf-cpp.exe* -rwxr-xr-x 1 User 197121 4040503 Nov 20 19:10 arm-none-linux-gnueabihf-dwp.exe* -rwxr-xr-x 1 User 197121 391769 Nov 20 19:10 arm-none-linux-gnueabihf-elfedit.exe* -rwxr-xr-x 2 User 197121 3030119 Nov 20 19:41 arm-none-linux-gnueabihf-g++.exe* -rwxr-xr-x 2 User 197121 3026926 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-10.2.1.exe* -rwxr-xr-x 1 User 197121 609607 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-ar.exe* -rwxr-xr-x 1 User 197121 609607 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-nm.exe* -rwxr-xr-x 1 User 197121 609607 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-ranlib.exe* -rwxr-xr-x 2 User 197121 3026926 Nov 20 19:41 arm-none-linux-gnueabihf-gcc.exe* -rwxr-xr-x 1 User 197121 2165533 Nov 20 19:41 arm-none-linux-gnueabihf-gcov-dump.exe* -rwxr-xr-x 1 User 197121 2343605 Nov 20 19:41 arm-none-linux-gnueabihf-gcov-tool.exe* -rwxr-xr-x 1 User 197121 2450233 Nov 20 19:41 arm-none-linux-gnueabihf-gcov.exe* -rwxr-xr-x 1 User 197121 9605899 Nov 20 19:54 arm-none-linux-gnueabihf-gdb.exe* -rwxr-xr-x 1 User 197121 3028997 Nov 20 19:41 arm-none-linux-gnueabihf-gfortran.exe* -rwxr-xr-x 1 User 197121 1412943 Nov 20 19:10 arm-none-linux-gnueabihf-gprof.exe* -rwxr-xr-x 4 User 197121 2572182 Nov 20 19:10 arm-none-linux-gnueabihf-ld.bfd.exe* -rwxr-xr-x 4 User 197121 2572182 Nov 20 19:10 arm-none-linux-gnueabihf-ld.exe* -rwxr-xr-x 2 User 197121 4550029 Nov 20 19:10 arm-none-linux-gnueabihf-ld.gold.exe* -rwxr-xr-x 1 User 197121 25546567 Nov 20 19:41 arm-none-linux-gnueabihf-lto-dump.exe* -rwxr-xr-x 2 User 197121 1404945 Nov 20 19:10 arm-none-linux-gnueabihf-nm.exe* -rwxr-xr-x 2 User 197121 1531656 Nov 20 19:10 arm-none-linux-gnueabihf-objcopy.exe* -rwxr-xr-x 2 User 197121 1991350 Nov 20 19:10 arm-none-linux-gnueabihf-objdump.exe* -rwxr-xr-x 2 User 197121 1421598 Nov 20 19:10 arm-none-linux-gnueabihf-ranlib.exe* -rwxr-xr-x 2 User 197121 1163376 Nov 20 19:10 arm-none-linux-gnueabihf-readelf.exe* -rwxr-xr-x 1 User 197121 1393083 Nov 20 19:10 arm-none-linux-gnueabihf-size.exe* -rwxr-xr-x 1 User 197121 1392464 Nov 20 19:10 arm-none-linux-gnueabihf-strings.exe* -rwxr-xr-x 2 User 197121 1531656 Nov 20 19:10 arm-none-linux-gnueabihf-strip.exe*The same archive file does extract properly under a native Linux Ubuntu 20.04 system, or under Windows 10 using the WSL2 Linux subsystem using xz and tar.
Hi I recently bought PowerArchiver and found some bugs and issues that I hit testing some of the features out.
If you are doing a backup and on the compression options screen its default is compression format is PA with no option to change disk spanning. If you change to 7-zip you can change disk spanning. If you change the disk spanning then move back to PA format the field for disk spanning disables but the option stays set to what you changed it to. When you do a backup it will use PA with files spanning but PowerArchiver says that its not a valid format when you open it. If PA can’t really do file spanning then this screen is allowing it.
I have attached an image where the progress bar is in the middle of the CD/DVD/BD Tools screen.
alt text
I have a 7-Zip file I created using the backup tools doing an increment backup. It opens and extracts just fine but if you using the Test option PowerArchiver locks up. Link to file: Backup-2021-02-05-20-35-36 TEST LOCKUP.7z
On any Zip/PA/7-Zip process the pause and cancel buttons do not work. You have to hard kill the entire application to get out.
There would be many of us with Intel Processors.
and they have their own optimized zlib algorithm, which can result in more efficiency if used combined with their hardware processor.
Reference:
https://www.intel.com/content/dam/www/public/us/en/documents/white-papers/zlib-compression-whitepaper-copy.pdfCan we get the same Functionality Under Hardware Acceleration Feature?
Zlib is not the only feature that intel has included with their processor, there’s many, which if combined can result in efficient and better compression ratios.
After the batch archiving is complete, and if I click on whitespace of the PA app, I get this error.
I did check for ongoing process and ensured no archives were corrupt, It seems like activity did complete successfully but the error is shown for no reason, and only after clicking the whitespace.
Please see if this can be removed.
I’m using the Kaspersky Total Security.
I have configured PA as exclusion as followed:
and also is set us trusted application
Scenario:
My Antivirus likes to scan for everything, and it’s safeguarding behavior is to prevent the access to the file until the file is properly scanned for.
The issue:
PA when losses the access to file, it is stuck, consumes Resources, and never completes the process or throws any error
Recommendation:
PAStarter should also work as PAMonitor:
There should be a monitoring process, at least if I’m using queuing feature, that should check for never ending compression processes and terminate them so the queue can be little bit automated.Also,
There should be multiple attempts at retrying if PA loses access to or is denied, instead of having to see process was stuck for longer duration.Or, better, save the parameters I used for keeping the files in compression, and automatically restart the whole compression process after termination the same, of same folders and files set, this should happen in case if compression was stuck.
If you use Queue Feature, you are not saving on space, you are just squeezing less.
Here’s explaination:
https://youtu.be/XcxG2wxyink
I did test the same on multiple files, and of different types.
It does have large difference for each large file you are trying to squeeze.
Folders with multiple files, just have no benefits if you use Queue Feature
I am using the portable version of PA2021. After switching from build 58 to 73 I have problems with the color-scheme:
While 58 behaves like expected and showed everything in light or dark colors according to the settings, 73 always shows the lower part of the window in dark colors, no matter whether I select automatic, light or dark.
This happens on a clean installation of 73 as well as on an update from build 58. I have attached two images generated on the same machine at the same time with the same settings. The upper shows build 73, the lower 58. Is it a bug or some changed setting I miss?
Thanks for help!
PowerArchiver Command Line 7 support file greater than 2 Go ?
If you have tabbed archive browsing(reuse same window for all archive opening)
and if you open two archives, and right click on older one to view properties it will only show of the recent archive that was opened, on all tabs/archivesupgraded to 20.0.73
Hi.
I currently own the PowerArchiver Select - lifetime free upgrades and support for PowerArchiver Toolbox English license.
This license is active on 1 device. Does the license allow me to activate PowerArchiver on a second device that I own? Or do I need a separate license for that?
Thank you ! :)
While the installable version of PA 2021 has already received two updates and is at version 20.0.73 the portable version still remains at the initially released build 58. Are there plans to update that version, too?
Thanks for a reply! -
I’ve been dealing with an intermittent explorer.exe crash for 5-6 years now. It happens randomly and will usually occur multiple times within a single session of an hour or two on my machine when manipulating files through Windows Explorer. explorer.exe is the only thing that ever crashes, so it’s not hardware IMO. I’ve done all hardware diagnostics and RAM is good. I’ve even swapped out motherboards with different brand and even the exact same one and it still crashes. sfc /scannow indicates system files are fine. I’ve done multiple reinstalls of the OS with no positive results. This crashing has happened on Windows 7 64-bit and Windows 10 64-bit. It seemed to get more frequent with Windows 10 after upgrading last year. I’ve also been using PowerArchiver throughout that time period (upgrading over time with new releases). I recently disabled all non-Microsoft extensions via ShellExView and saw no crashes for about 10 days, which is really unusual. I turned back them all back on after 10 days and saw another explorer.exe crash within the hour. So I disabled all 32-bit extensions and saw another crash. Following that I disabled all the PowerArchiver shell extensions and haven’t seen a crash after a day of heavy usage manipulating files within Windows Explorer, which doesn’t happen for me. The crash dumps I’ve captured don’t seem to indicate PowerArchiver is involved but I have a hunch it has something do with PowerArchiver shell extensions. The system even feels smoother with the PA extensions disabled. Windows 10 reliability monitor always has the same type of problem:
Description Faulting Application Path: C:\WINDOWS\explorer.exe Problem signature Problem Event Name: BEX64 Application Name: explorer.exe Application Version: 10.0.17134.165 Application Timestamp: 4031a9f8 Fault Module Name: StackHash_e78e Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Offset: PCH_8D_FROM_ntdll+0x000000000009AA54 Exception Code: c0000005 Exception Data: 0000000000000008 OS Version: 10.0.17134.2.0.0.256.48 Locale ID: 1033 Additional Information 1: e78e Additional Information 2: e78e327659b46c9a0c6916396b253cbf Additional Information 3: cebf Additional Information 4: cebf952c5db535ae7880488aafce55d9 Extra information about the problem Bucket ID: 1a57e4e784fbc735c231c68bd88581a9 (1311047270476906921)I know this is a very nebulous explanation but is there any way to link this up to PA shell extensions as the cause? I can provide the crash dumps and additional information if necessary.
When you select “Deflate (.zip, compatible)” as the method, it still converts the archive to a ZIPX format.
Would like to see uha archives supported compression as well as extraction. I use this all the time and it is a very good compression format
In windows 10 you can right-click and select send to and the compressed zipped folder and the zip folder will contain the name of the last selected file.
Does PowerArchiver have a similar function?
Tom
Converting an archive to .zip (using both the “Deflate (.zip, compatible)” and “Store” compression methods) always creates a .zipx file instead.
pa-convert-zip-2.jpgUsing the “Store” method sometimes creates a .zip file; I have seen it happen just now, but I cannot reproduce it.
patchbeam a waste of time never updated with latest version
I have just installed 2021, but seems to have similar issues to 2019. If you move the app between differen monitors (with different resolutions) the app does not automatically adjust accordingly, so on one monitor I have the app is too big for the screen, whereas on another monitor it only takes up a small fraction of the screen.
This was worse with 2019, where the fonts were totally screwed up, making the app unusable. This seems better in 2021, but still not working properly. -
Hi! I came across an issue when I tried to uninstall PowerArch 2013. I got an error “The specified account already exists” which broke the process. I got the same error when I tried to install the current version, without uninstalling the previous one.
So I can’t uninstall and I can’t install PowerArchiver. Any suggestions? OS Windows 8.1 x64.Dariusz
Virtual Drive Issue
I have reported this before but not pursue it too much here. I use another drive emulator which works perfectly. But I don’t like computers to win!
The problem is that when I mount an image file, a drive letter is not given, and unmounting the image a) does not clear it from the wizard and b) a second attempt causes a BSOD crash. There are no other issues with my Win 7 x64 installation regarding drive letters or partition management.
The virtual drive does work on other windows setups so something strange is going on. I have searched for similar issues and turned up nothing. I am using the latest drivers, viz SPTDinst-v183-x64.
Any ideas?
Regards
DrT
strange… nobody else reported something similar, maybe something is clashing? Lets see with upcoming 2013, soon.
I have not got a hope in hell of tracking this down as everything else works fine. I can create drive letters without issue too.
The only hope would be if somebody else were familiar with this. Will 2013 deal with the virtual drive feature identically or will it have been modified in some way?
Regards
DrT
there is some new code so we will see…
After reading some other posts about issues being fixed by an uninstall and then a reinstall, I gave it a go and it’s fixed. UPDATE:-only fixed for one go. Does the uninstall clear out all the registry settings? If not, howcan I start from a default install?
DrT
thats strange… beta should be within 7 days.
wait, how come you are not alpha tester?
Still having the problem with the beta (14.00.16).
I am having the same issue with Starburn software (I believe that you used the SDK?) except that Starburn can remove a non-showing drive. These drives to not appear in Disk Management so I cannot manually add a letter.
i wish we could reproduce it here somehow, would give us ability to troubleshoot it.
I am happy to run any tests or debug version or do any registry editing/sleuthing to assist. Do you get any preferential treatment from the StarBurn people as you are developers rather than end users? I have also left a message on their forum.
Regards
DrT
hi,
i’ve got exactly the same problem with the virtual drive.- i had elby’s virtual clone drive installed.
- uninstalled it, bit didn’t reboot (probably a mistake).
- downloaded and installed virtual drive through patchbeam.
- then tried to mount an iso, which caused windows to try to install a driver, but ended in a loop. tried shutting windows, which didn’t work.
- had to do a hard power off. then reboot.
- after reboot tried again to mount iso, which worked
- dismount iso also worked
- tried mounting the same iso again -> no response
- tried to dismount the iso (which ha no drive letter assigned to it)
- tried again to dismount the iso, which now hat two entrys in the list of mounted drives (again without any drive letters)
-BSOD
i use intel raid storage drivers
I supplied all the info Starburn requested and they could not see anything wrong. They did not reply to my last email (just come back from hols) so have sent them a ‘bump’.
I can mount a virtual drive just fine.
And I can unmount it from the system tray. No problem.
However, the “Unmount virtual drive” from within the Windows shell does not work. I DO get a message near the tray saying that the drive is unmounted. However, the drive still shows as an active drive within Windows explorer.
So the problem I have is just with the shell option.
