    Can't burn iso, registration code doesn't work
    2 Posts 2 Posters 2.7k Views
    • B Offline
      bgillon
      il have PA2012 Professional.
      my registration works for PA.
      but if i want to burn iso file, splash screen appear and ask to enter registration code.
      if i use my registration code, splash screen doesn’t hide… and i can burn iso file…
      Regards,
        The PRO version does does allow you to burn files to disc, but the burn disc as ISO option is available in the Toolbox version only.
        I guess if you have the PRO version it should not show you the option to “burn disc from ISO”
        I’ll log that in so it does not show anymore for the PRO version.
