    PAStarter
    5 Posts 2 Posters 3.7k Views
      Socrates Banned
      As I explained in an earlier note, I reinstalled PA (.26) using the download from the front page.
      A new problem.
      Whenever I close a PA window, it ALSO closes PAStarter – which I don’t want. That is usually the way I start PA.
      Perhaps it was an unintended knock-on effect of some change in the installer.
      Also another minor glitch. This occasionally happens before, but now . . . everytime.
      I HAVE to have queue enabled for starter to work. Unless I do, when I close PA, it automatically closes starter – every time.
        seems to work fine here.
        Whether I close by going to File>Exit or clicking on X on upper right corner, PA starter stay available.
        Anyone else?
          Socrates Banned @Mili
          Did you try it with Queue not enabled?
            Yes, have tried both instances and starter stays available after exiting PA in both.
              Odd. Well, it is likely a peculiarity of my system. Thanks for checking.
