    Compression profiles
    26 Posts 3 Posters 14.3k Views
      I was finally able to figure it out.
      It happens when dragging a file onto a Zipx archive, in windows explorer for example. (file not open in main PA)
      Logging it in.
      S spwolfS 2 Replies Last reply Reply Quote 0
        Socrates Banned @Mili
        Thanks.
        Sorry it took me so long to explain it clearly. My bad. That is almost always the way I add files to an archive, so I erroneously assumed most other people did the same. Duh. I am slow.
          I didn’t try ALL D&D options myself so my fault as well :)
          Thanks for bringing it up, glad we got it!
          logged in :)
            Socrates Banned
            Goodness. No need to apologize. It is my job to explain the problem clearly. You all have a difficult enough job as it is.
            I am just glad I was finally able to explain it clearly enough.
            Thanks for a great product.
              spwolf conexware @Mili
              @Mili:
              Logging it in.
              ah, dragging into the icon? :-).
              you see how many different scenarios there are!
                Socrates Banned @spwolf
                Many ways of doing it. But D&D onto the icon always seemed the easiest.
                Which is why I would also like to be able to move or copy depending on which keys I hold down while D&D (which key combinations matters now) — just as move seems the default in Win 7, but holding down the CTRL key while doing it copies the file.
