    Archive Converter and 7-zip
    8 Posts 8 Posters 13.1k Views
    • T Offline
      tehmul
      If an archive is converted to 7zip format using Archive Converter, it doesn’t seem to turn solid compression on. :eek: I tried this both with and without compression profiles. Manually converting to 7zip works well, but is quite tedious for multiple zip files.
        @tehmul:
        We will turn it on by default for converter in next version.
        D K 2 Replies Last reply Reply Quote 0
          davidsplash @spwolf
          I would prefer you just added a tick or option box that you click to make solid archives for 7zip i don’t use them but i do use normal 7zip files. I regulary use the converter for this purpose
          • K Offline
            klumy @spwolf
            yeah a acheckbox would be good
            • A Offline
              amh209 @klumy
              I also vote for checkbox (if anyone is asking my 2 cents).
              SpAwN oF T.D.F.S 1 Reply Last reply Reply Quote 0
              • SpAwN oF T.D.F.S Offline
                SpAwN oF T.D.F. @amh209
                And everybody knows it…i vote for that too!
                manuangiM 1 Reply Last reply Reply Quote 0
                • manuangiM Offline
                  manuangi @SpAwN oF T.D.F.
                  another vote for the checkbox!
                  the more customizable, the better! ;)
                    ivan conexware @manuangi
                    This goes on wishlist for 9.1. Currently Solid compression is turned on by default.
