    File listing problem with bigger files
    10 Posts 4 Posters 4.9k Views
    • J Offline
      Jeremiad
      Seems that there’s problems listing “detailed” information from bigger Zip files. In this case i have 47Gb zip file.
      Zip’s structure is: Main folder -> 2 sub-folders and so on.
      And when its trying to get detailed information from this main folder it fails. Window stays blank. Doesn’t even show the main folder. If i switch to list view, thumbnails or something else it works just fine.
      And also is there a way to change language to English in international version?
      PA version is: 13.00.24
      • LuxorL Offline
        Luxor Alpha Testers
        Welcome Jeremiad
        I’ll let support answer your first question. ;)
        As for your question regarding changing languages, if you are using the modern interface you should have the option “Change language” in the Options toolbar as shown in my screenshot. If you are using the classic interface it is under Options > Change Language.
        Windows 10 Home 64-bit
        • J Offline
          Jeremiad @Luxor
          Hehe, I must be blind for not spotting that. Thank you!
            @Jeremiad:
            how many files inside?
            • J Offline
              Jeremiad @spwolf
              Odd, now it seems to be working when language is English. This problems was when PA was in Finnish.
              Theres 24 files and 12 dirs.
              So problem is that its missing translations?
                try again in finnish and what happens? If it still doesnt work, save your settings via Config button> Export settings and send them to support at conexware dot com.
                I have tried Finnish and all seemed fine but i probably dont use same options as you.
                  well, i see now that something similar was fixed in upcoming release - “file contents not seen when changing languages, only with some languages”… does that sound familiar?
                    davidsplash @spwolf
                    is there a limit on the size of zip file as every archiver has a limit.
                      spwolf conexware @davidsplash
                      @davidsplash:
                      there is no practical limit, it is in petabytes or something like that… i think problem was with translation, nothing else.
                        spwolf conexware @Jeremiad
                        @Jeremiad:
                        please check PA 2012 13.00.25 via Patchbeam and see if it works better now… thanks!
