    Issue with virtual drive
    27 Posts 7 Posters 18.4k Views
      Socrates Banned @vinko
      Are you running PA with administrator privileges? If not, the installation may not work.
      Or perhaps you are not running the setup on your VD with administrator privileges.
      Since this is not a problem I have ever heard mention, I am betting that it is a problem with a setting like those mentioned above, or some other clash on your system.
        Hi Vinko,
        Were you able to install the VD drivers properly?
        If not, here is the direct link to them;
        http://dl.patchbeam.com/conexware/pavdint2012/files/pastarport15003int.exe
        If you have, then what errors are you getting when trying to use the VD.
        Also, please do try running PA as admin as noted by Socrates and see if that helps.
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          vinko @Mili
          re-install Windows 7 was the only solution …. PA 2012 Toolbox is now working very well…
            Glad it was fixed. But what a time-consuming solution. Sorry.
              Glad it works Vinko!!
              • moles42M Offline
                moles42 Alpha Testers
                I’d be lost without my virtual drive…:)
                Windows 10 Pro x64
                Intel Core i5 3470 @ 3.20GHz
                8.00GB Dual-Channel DDR3
                  who knows, probably some driver messed up all the virtual drives as you tried them all…. I will be closing this thread so if something else comes up, open new one… thanks.
