    Issue with virtual drive
    27 Posts 7 Posters 17.5k Views
    • B Offline
      BookWyrm
      I’m running the PA 2012 beta with the virtual drive.
      I can mount and access the ISO files without issue, but there is an issue when I go to unmount or remove the virtual drive.
      The initial attempt says everything succeeded, but then I get a message from Windows that it was unable to remove the device and the drive remains mounted.
      Running Windows 7 SP1 x64.
      • RJWaringR Offline
        RJWaring
        Bookwyrm,
        Thank you, for your post.
        Can you verify that you have downloaded Beta 2 (12.00.18)
        I can clarify that this is a known issue the alpha team and developers have been discusing.
        You should be able to Unmount the drive by right clicking on PAStarter and Selecting “Unmount & Remove Device…”
        Try and ensure the “My Computer” Window is closed to ensure this unmounts the device.
        It seems that when the user is in “My Computer” it goes through the process of unmounting but something is locking PoweArchiver’s Driver from doing it. But when the user removes the drive using other dismount options in PA’s program it works.
        My view on this is the 1st port of call for a user would be to right click on a device and dismount it. Although, there are other ways this shouldnt mean we should give up and find a fix. :)
          @BookWyrm:
          did you by any chance download and install beta 1 first?
            Socrates Banned @spwolf
            I have always occasionally had this problem too with successive versions of PA. But if I did, I just went to the “Safely Remove Hardware” icon in the system try, clicked on the VD I wanted to remove, and that solved the problem. Always seemed, at most, like a minor glitch, one with an easy workaround. Besides, I assumed (perhaps wrongly) that it was just something else going on somewhere in my system.
              spwolf conexware @Socrates
              @Socrates:
              there was an bug in b1 that made it impossible to unmount VD, it was fixed in b2 however it involves that user uninstalls the driver and reboots before installing new one. Which is why i asked if he used b1.
              • B Offline
                BookWyrm @spwolf
                I did indeed use B1 and upgrade to B2. I’ll do the uninstall of the virtual drive and reboot/reinstall and see what I get.
                • B Offline
                  BookWyrm @BookWyrm
                  Unfortunately the uninstall/reboot/reinstall did not seem to resolve the issue. :(
                    spwolf conexware @BookWyrm
                    @BookWyrm:
                    did you uninstall PowerArchiver Startport drivers, reboot and then downloaded and installed latest drivers? It has to work :-)
                    • B Offline
                      BookWyrm @spwolf
                      I did the uninstall via Programs & Features control panel and rebooted.
                      The install of the latest drivers, I just opened PowerArchiver and selected Virtual Drive and let it install them. According to PatchBeam the virtual drive is version 1.05.02
                        but you uninstalled the drivers right? Since uninstalling PA wont do anything.
                        Patchbeam just shows virtual drive version, not actual driver version.
                        • B Offline
                          BookWyrm @spwolf
                          The app I uninstalled via Control Panel was “StarPort Drivers for PowerArchiver Virtual Drive Emulator”, I assume that’s the right one?
                          The controller I see in Device Manager is ‘StarPort Storage Controller (Lite)’. The drive is StarPortLite.sys with version 3.5 Build 20080111
                            that should work… how are you unmounting? Did you try via shell or any other way?
                            • B Offline
                              BookWyrm @spwolf
                              I did the unmount via the PowerArchiver gui; selected the Virtual Drive from the ribbon and selected unmount.
                              Is there a different way to try?
                                lets try this,
                                Uninstall Starport drivers
                                reboot computer
                                download and install this driver;
                                http://dl.patchbeam.com/conexware/pavdint2012/files/pastarport15002int.exe
                                V 1 Reply Last reply Reply Quote 0
                                • V Offline
                                  vinko @Mili
                                  why I can not install any games with PA 2012 Toolbox?Is there any solution for this?
                                    Vinko,
                                    What sorts of issues are you having which make it seems like there is something wrong with PA VD?
                                    Personally, I’ve installed some programs/games using PowerArchiver’s VD and it worked fine. Of course, that does not mean it has to work fine for you.
                                    Please let us know some details and we’ll do our best to help.
                                    • V Offline
                                      vinko @Mili
                                      I want to install the game. I choose .iso image, right click, mount VD and then wait VD and nothing happens….
                                        Vinko,
                                        Please try the following;
                                        Open PowerArchiver
                                        Go to the Burner menu
                                        Click on the Virtual Drive button
                                        You should be asked whether to install drivers, click Yes.
                                        Once they are installed, go back to the same Virtual Drive button and click it, you should get PA 2012 VD working then and the right click option should also work as well.
                                        Let me know if that worked.
                                        • V Offline
                                          vinko @Mili
                                          no luck …. now I have a computer crashes every time when PA VD wants to install software…
                                          how sorry I am that I bought a license for PA 2012 Toolbox
                                          • V Offline
                                            vinko @vinko
                                            I also tried with daemon tools and Alcohol 120% and even with these softwares I could not install the game and office… what could be the cause of my problem?
