    PowerArchiver 2012 Toolbox Legacy vs PowerArchiver 2012 Toolbox
    5 Posts 3 Posters 7.6k Views
    • K Offline
      Keith Weisshar
      I have previously purchased upgrade to PowerArchiver 2011 Toolbox from Pro when PowerArchiver 2011 was released and then when PowerArchiver 2012 beta was released, the account shows PowerArchiver 2012 Toolbox Legacy under free upgrades and PowerArchiver 2012 Toolbox English under available upgrades. What’s the difference between PowerArchiver 2012 Toolbox Legacy and PowerArchiver 2012 Toolbox?
        there isnt any… only difference is version with BD2012.
          The “legacy” version refers to earlier versions of PA Toolbox.
          The new PA 2012 Toolbox includes the Bitdefender Offer.
          See http://www.powerarchiver.com/powerarchiver-toolbox/?frontpage
          • K Offline
            Keith Weisshar @TBGBe
            I noticed there are separate available upgrades in my account, PowerArchiver 2012 Toolbox without Bitdefender for 60% of $49.95 and PowerArchiver 2012 Toolbox with Bitdefender for 65% of $59.95.
              spwolf conexware @Keith Weisshar
              @Keith:
              it is just because you probably had standard version before, which you upgraded earlier but PA store doesnt track updates, just gives you discount…
