    Will it be possible to invoke FTP by icon in the future?
    8 Posts 4 Posters 6.6k Views
    • P Offline
      PALarsen
      Hi.
      I was wondering if it would be possible to get support for icon “commandline” like
      -FTP or -Virtual or -Burner and so on.
      http://www.litopa.dk/likethis.png
      So it would be possible to invoke the part the ICON is meant to start.
      I’m not that good at English, hope somebody get the idea :D
      Sincerely.
      PLarsen
        might be already possible, i will check…
        • RJWaringR Offline
          RJWaring
          Actually,
          This is a very good point. PowerArchiver has Icons in it’s install folder for it’s Burner, Drive Emulator and Backup applications but nothing for its FTP.
          So could we have a launcher icon for FTP please.
            I think PALarsen is meaning a command line option rather than/as well as than icon.
            Look at the attached picture!
              it is the same thing, if there is an icon, there would be a way to call PA FTP directly, and that would be via cl switch :-)
                @PALarsen:
                Hi.
                Sincerely.
                PLarsen
                just FYI, you can start all but PA FTP currently via their program files in PA installation folder… they are separate.
                • RJWaringR Offline
                  RJWaring @TBGBe
                  @TBGBe:
                  I did look at the picture ;) and said “this is a good point” then i listed another “what would be nice” indicating an additional adjustment to that request being a new icon to launch ftp itself.
                  • P Offline
                    PALarsen @RJWaring
                    First.
                    Thank you to all who replied, you seems to be a nice bunch of people, I think I’m going to enjoy the forum as much as I enjoy the program :)
                    I found the standalone programs, and yes a PAFTP.exe in that collection would be a great thing, but “-FTP” startup option would be good enough.
                    Once again, thanks for the great feedback on my question.
                    Palle.
