PA - 12.11.02 - FTP Not connecting
Not sure yet, will check though :)
I’ve also checked this;
2. When the user clears the port number as 0 or nill on save it defaults it to 21 or whatever number relivant to the mode. [ stop this please, if a user has removed it after it being there in the 1st place they wanting to]If you enter zero in the port number field and save it as that, than zero is saved.
If you just clear the port number field and leave it blank, it goes back to 21 as that is default, which seems correct, no?Seems logical, I know in FileZilla it is kept Blank if cleared, but obviosly in the background it keeps it as default.
It might be worth you downloading Filezilla its freeware and opensource. It might give you guys a platform to compare against your own FTP and roll out enhancements.
@Sir:
simply copying everything from another ftp is not going to happen… if there is specific wish to be had, there is wishlist. Our FTP is there to save you time compared to others when using common tasks which 99% of people use, not for billions of features. It is like PA vs WinZip - FTP is designed to be more of WinZip, in having crucial features :-).
I’m not asking for you to copy it but I expect powerarchivers ftp to work if not better than a commercially available freeware program.
And I know it did during development so it’s frustrating having a tool I used to have working and now I can’t and now. Have a freeware doing a better job…
As soon as its fixed the filezilla can be uninstalled and I can start using my favourite backup tool for ftp transfers again.
@Sir:
patience, you just reported the bug… you should have reported it first time you got it :-)
Check this out:
www.powerarchiver.com/test/alpha120/powarc121201.exe -
BOOM! SUCESS! FIXED! RESOLVED!
I am now able to connect to my livedrive account as fast as a commerically available ftp client! with no current sign of issues.
I obviosly, will be testing this out and let you know if there is a problem but from my 1st impression its back to what it was during alpha development.
Thanks team! you made a pro user very happy.
wham bam thank you mam!
