    Module could not be found
    13 Posts 5 Posters 6.2k Views
    • X Offline
      xcrossing
      Hello:
      Never had any problems untill Win7
      PowerArchiver 2011
      will not right click unpack nor pack in same folder.
      What the …… is cancelbutt
      I hate features! all I want to do is unpack or pack a *zip type of file. but NO I have to jump thru hoops to do a simple task
      WORKER11811
        @xcrossing:
        Any error messages?
        @xcrossing:
        Good question - where do you see that?
        It could be a faulty install - have you tried re-installing?
        Perhaps a screenshot?
        • A Offline
          amh209
          If I understand your question, when you right click on a zipped file, there is no menu there that says extract to or extract here (both options are available).
          If you open PowerArchiver, options, configuration, select the shell extension. On the shell extension menu, you have two choices under menu items (Compression and Extraction). Select the correct tab and add the missing options to your right click menu.
          Also, I haven’t seen the error message ‘cancelbutt’ before.
            @xcrossing:
            Hello:
            PowerArchiver 2011
            WORKER11811
            It seems you need to re-install PowerArchiver.
            So uninstall PowerArchiver, and then install it again.
            X 1 Reply Last reply Reply Quote 0
            • X Offline
              xcrossing @spwolf
              Yea…I checked that (open PowerArchiver, options, configuration)
              I will reinstall
              Its getting late will send screenshots mon nite.
              I’m not kidding about cancelbutt.:rolleyes:
              WORKER11811
              who was worker11811?
              hint: very old movie
              • moles42M Offline
                moles42 Alpha Testers
                ‘Worker 11811’ is from the film ‘Metropolis’ (1927) by ‘Fritz Lang’ as I recall…you must be older than I first thought…:)
                “Radio Gaga” springs to mind…:)
                Windows 10 Pro x64
                Intel Core i5 3470 @ 3.20GHz
                8.00GB Dual-Channel DDR3
                • X Offline
                  xcrossing @moles42
                    did you try reinstalling?
                      it is same problem as here:
                      http://www.powerarchiver.com/forums/showthread.php?t=5230
                      basically one of the dll’s either doesnt get registered or gets unregistered, which means it will not work properly. Uninstall and Install again and registration should work fine as will everything else.
                      • X Offline
                        xcrossing @spwolf
                        Not yet. Just wanted to show you cancelbutt
                        Doing other things right now.
                        Will let you know as I re-install .
                        WORKER11811
                        • X Offline
                          xcrossing @xcrossing
                          Thanks for your patients and quick replys
                          I have much more time behind me than in
                          fron….t…o…f…meeee…:eek:
                          WORKER11811
                            works fine now?
                              “cancelbutt” (and “CorelButton1”) are just coding labels.
                              You only see these when something is not installed correctly.
